NP435 4th gear grinding
Old Aug 30, 2006 | 11:50 PM
MychalCrowson's Avatar
MychalCrowson
I have a 71 F250 4x4 with the 435 and recently had the tranny out to replace the output shaft i believe its called, and other than the shaft it seemed all was well. Shortly thereafter it became impossible to shift it into 4th gear without it grinding. Im able to minimize it by double clutching and keeping the rpms right, but the grind is unavoidable and its only 4th gear, all others shift fine. has anyone else had this problem? I was hoping there was a way to adjust the clutch but if not am i going to have to pull it back out and look at the fork and gears? I'd like some feedback before i go taking that thing out again its a pain. But like i said, we just had it out and the fork and gears seemed fine. thanks for any help.
Old Aug 31, 2006 | 12:56 AM
Bdox's Avatar
Bdox
Sounds like something in the syncro assy was not put back correctly.
Pull the cover with the shifter from inside the truck? I can do this on mine but it's an 86. Hopefully you can spot your problem without dropping the trans.
Old Feb 23, 2014 | 03:42 PM
77F-150's Avatar
77F-150
Im having the same issue on my 77 ford f150, its four wheel drive and all and mine is only grinding in 4th gear, i managed to remove the top cover but how would i know if everything is alright inside im be no means a tranny type guy. Could something with the forks be the cause of it also? referring to the top cover?
Old Feb 23, 2014 | 03:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Feb 24, 2014 | 12:19 AM
77F-150's Avatar
77F-150
What type of gear oil would this transmission use or recommended for it?
Old Jan 27, 2015 | 04:46 PM
77F25077's Avatar
77F25077
80-90w works good
windyhill
Oct 16, 2016 11:42 AM
tananaBrian
Oct 9, 2015 05:51 PM
fisher4life
Sep 30, 2014 08:28 AM
77F-150
Feb 2, 2014 10:20 PM
rollinblackcloud
Aug 27, 2012 05:22 PM
