Smoke Situation
Old Aug 30, 2006 | 11:40 PM
Fuxton1's Avatar
Fuxton1
Smoke Situation
I have a 2007 F350 with a mbrp turbo back, k&n intake, and a bully dog triple dog power pup. when i accelerate i get a puff of white smoke, then i get the usual black smoke. There is no loss in power. I checked the coolant and im still full. I was just wondering if i should be worrying, and what it could be.
Old Aug 31, 2006 | 08:45 AM
kw5413's Avatar
kw5413
Welcome to FTE and the 6.0 forum Fuxton1
When you get a chance you might want to cruise over to our Tech Folder for some great 6.0 info.
https://www.ford-trucks.com/forums/showthread.php?t=303583
Please take a few moments to read our site guidelines as well.
https://www.ford-trucks.com/guidelines.html
Old Aug 31, 2006 | 11:32 AM
BowTieHatr's Avatar
BowTieHatr
could be moisture buildup in the system
Old Aug 31, 2006 | 04:01 PM
hschiro's Avatar
hschiro
Just had the same issue, could be moisture but mine needed a new turbo. Replaced under warranty in 1.5 days, no problems since. Good luck.
Old Sep 1, 2006 | 07:52 AM
Fuxton1's Avatar
Fuxton1
Thanks for the responses guys. I forgot to mention that it only happens when i take off from a complete stop. If im already moving i cant notice it.
Old Sep 1, 2006 | 09:25 PM
hschiro's Avatar
hschiro
That is the same situation that I had with mine. Only white smoke at take off. It started out slight, then after a few more days it got heavier. I'm not sure why the turbo was the issue, but its been 2 weeks since the replacement and have not had any white smoke. The dealer tried first to clean the turbo and the erg to no avail, then replaced turbo. They said it had oil residue inside of it, indicating a slight leak. let us know how it goes.
Old Sep 3, 2006 | 01:56 PM
BowTieHatr's Avatar
BowTieHatr
all turbos are going to have the oil residue because of the ccv system.
Old Sep 3, 2006 | 07:59 PM
hschiro's Avatar
hschiro
Thanks bowTieHatr. Do they leak often?
Old Sep 3, 2006 | 08:03 PM
BowTieHatr's Avatar
BowTieHatr
does what leak often?
Old Sep 4, 2006 | 12:32 PM
hschiro's Avatar
hschiro
I figured the ccv system was a lubrication system for the turbo and may leak at times?
Old Sep 4, 2006 | 12:51 PM
BowTieHatr's Avatar
BowTieHatr
i am sorry for being short. ccv is crankcase ventilation system. it will put oil vapor in the intake system and it will be everywhere. now it the oil seal went out in the turbo you would leave a trail of oil everywhere you went and you would not go far with this big of leak.
Old Sep 4, 2006 | 09:35 PM
hschiro's Avatar
hschiro
Thank you for the information. It's great being able to find out about these trucks from those who know them.
Old Sep 12, 2006 | 12:54 PM
Fuxton1's Avatar
Fuxton1
Just an update, i brought it in to the dealership and they said they cant warranty anything because i removed the cat. She goes into telling me that whatever is wrong (because the didnt even look) is most likely cause by the decrease in backpressure. I hate dealerships.
Old Sep 12, 2006 | 02:05 PM
kw5413's Avatar
kw5413
I don't mean to offend. This is an honest question. But, do you think the mbrp turbo back, K&N intake and or the bully dog triple dog power pup...or a combination of all three might have something to do with the warranty denial?
Old Sep 12, 2006 | 02:37 PM
hschiro's Avatar
hschiro
Replace your CAT, take the programmer off and go to another dealer.
