...Welcome AK to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Thanks Al for the info, who sells the Exploder kit. I might have to come up with something else if I can't find one close to Alaska. Frieght is a killer up here.
Thanks wintremute, I was afraid that was the case. I was hoping for a company that sold kits like the ones for a Toyota upgrade to v-6 or v-8. I will have to look around the area and see if I can't call in some favors. Thanks
As you can probably tell I am not a Ford guy, it came with my wife, at least the truck is paid for. I did not know the Rangers came equipped with a V-8, I have a lot of research to do. I talked to the shop around the corner from home and his quote is close to 5K for the total swap. I definately have to check all my options, thanks for the info.
I am going moose hunting in the AM so I will check in when I return, thanks for the info, what I need is the easiest way I can find. See ya in a couple of weeks or so....
