Taillight problem
Old Aug 30, 2006 | 10:25 PM
Wear's Avatar
Wear
Taillight problem
I have an 85 f150, while putting in a new cd player I accidently blew the flasher fuse. So after replacing it, my taillights only work when braking and when I use either turn signal both tail turn signals blink at the same time, also the reverse lights also dont work at all. The front lights all work correctly. I have no idea whats wrong please help. Any help would be greatly appreciated.
Old Aug 31, 2006 | 05:47 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 31, 2006 | 06:18 PM
Franklin2's Avatar
Franklin2
There are too many different types of problems going on in your post at once. What was involved in putting in the player? Why did you blow the flasher fuse, this circuit has nothing to do with the stereo circuit.
If I had to guess, it sounds like you have gotten into the steering column wiring somehow. The flasher does go to the steerin column as well as the turnsignals to the rear.
Old Aug 31, 2006 | 09:05 PM
Wear's Avatar
Wear
when i took the stock radio out I accidently touch the power wire to a metal bar in the dash which is connected to a ground wire, some how the flasher fuse blew I dont know why, and i replaced the fuse, still no fix. But today I found a bad bulb, the one on the passenger side, its not on the front of the truck its on the side. Also today I tried to follow the wires from the rear to the front looking for a bad ground but could not find any ground along the frame, i looked every where all the way to the front and lost the wires in the firewall. If its in the steering column what would I look for. Thanks
Old Aug 31, 2006 | 09:50 PM
o7dgm's Avatar
o7dgm
Youre tail lights should be grounded to the fender.If you lose the ground to one side sometimes they will ground thru the other light so both sides blink.
Old Aug 31, 2006 | 09:56 PM
Wear's Avatar
Wear
I think I have an after market fender, But Ill check, thanks
Old Aug 31, 2006 | 10:22 PM
Franklin2's Avatar
Franklin2
If you hit the brake, and both rear lights light up, then that tells you the wiring from the turnsignal switch to the rear lights is ok. The brake power goes through the turnsignal switch in the column.
Both sides blinking seems like there is a wire melted together in the harness, or the turnsignal switch is bad.
Old Aug 31, 2006 | 10:26 PM
o7dgm's Avatar
o7dgm
the screws that hold the light to the fender ground the lights.
Old Sep 1, 2006 | 05:52 AM
Wear's Avatar
Wear
When the head lights are on the brake lights dont work but with the headlights off the brake lights do work.
Old Sep 1, 2006 | 01:48 PM
Franklin2's Avatar
Franklin2
Ok. That's a sign that the rear lights have lost their ground. This can be caused by a corroded connection from the brass part of the bulb to the socket, a bad socket, or a bad connection at the ground wire connection for each light.
Since it's both sides, i would be suspicious that if the bulb grounds go to the bed, then the bed may have lost it's ground to the frame.
What's happening now is the brake lights are using the running light circuit for a ground path, since the real ground is gone. As soon as you turn on the headlights, power is sent to the running lights in the rear, so the brake lights lose the ground path they had found, so they quit working.
Old Sep 1, 2006 | 04:02 PM
Wear's Avatar
Wear
So that would also cause the running lights to not work also?
Old Sep 1, 2006 | 05:04 PM
Franklin2's Avatar
Franklin2
I forgot the running lights did not work in the rear.
This is a very confusing problem you have here. Certain circuits usually have certain failure modes or patterns. If everything worked before, and now doesn't after the stereo install, then that throws a whole monkey wrench into the troubleshooting and diagnosis.
Let's back up here a little bit. Everything worked perfectly before the stereo install? And right after the stereo install and replacing the fuse, you had all the problems?
The reason I am asking is I do not want to throw in the most common failures like corroded grounds and such. It could be something like that, but it would be an unusual coincidence if everything went haywire right after the stereo install. And since the stereo power wire has nothing to do with the flasher circuit, I feel there is something else going on here, like other damaged wires.
I am curious. Does the cd player actually work correctly?
Old Sep 1, 2006 | 05:52 PM
Wear's Avatar
Wear
Yes, it works perfect since I hard wired it to the battery
Old Sep 1, 2006 | 09:56 PM
Wear's Avatar
Wear
Well tonight I bought all new bulbs for the tail and a Haynes manual. Hopfully I can take what you guys have said and the book and find the solution.
Old Sep 2, 2006 | 05:19 PM
Wear's Avatar
Wear
So I found out today that one bad bulb can throw all my tail lights out of wack. Al I did was replace all of the bulbs in the tail and they all work now, funny how what you least expect the problem to be could the answer. Thanks for all you help guys.
