Removing the pcm?
Old Aug 30, 2006 | 08:39 PM
tuke's Avatar
tuke
Removing the pcm?
Ok I found it. Its behind the drivers side kick panel. Is it suppose to be loose? Seems like I might be able to pull it through the firewall into the engine compartment after I disconnect the 60 pin connector. Or do I have it all wrong? Help I want to remove it to clean the conncetions and see what the number is on it. Thanks Ed
Old Aug 30, 2006 | 09:59 PM
PLC7.3's Avatar
PLC7.3
Last time I saw it removed they went behind the plastic inner fender......
Old Aug 30, 2006 | 10:06 PM
tuke's Avatar
tuke
Yeah but then the e-brake braket comes into play. I'll have to take another look tommorrow see if I can squeak it out that way.
Old Aug 31, 2006 | 03:16 PM
tuke's Avatar
tuke
Well got it out through the firewall. Once you get it unplugged from the wire harness their are 2 nuts holding a rubber seal to the firewall that needed to be removed. Then I had to remove some screws holding the plastic wheel well in place. Then the eec slides out. Apparently mine has been replaced it was a remanufactored unit. Opened it up for hah hahs to see if there were any signs of things that may be cooked, looked ok so I cleaned up the terminals and reinstalled.
