Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
gas mileage
Old Dec 29, 2006 | 08:35 PM
  #31
slowants's Avatar
slowants
JFusion is right about the 6 cylinder plugs, get a Haynes manual, follow the directions, and anyone can do it. Make sure you have the right size spark plug wrench with enough of an extension to get to them, and its a piece of cake.
Old Dec 30, 2006 | 07:50 AM
  #32
JFUSION's Avatar
JFUSION
yeah it really looks intimidating when looking at it from above the engine bay, but once you get into it and start pulling off the appropriate parts you quickly see what needs to be done and it goes pretty quick.
Old Dec 30, 2006 | 12:37 PM
  #33
tcesni's Avatar
tcesni
I changed my plugs at 108,000 miles and had no issues in removing them with a simple socket and ratchet. Just take your time and follow the directions on this web site and its no big deal.
Old Jan 31, 2007 | 08:24 PM
  #34
DBSweeney's Avatar
DBSweeney
I think I'm gonna get the Haynes manual and try to replace the plugs on my wife's '03 Escape LTD. Would you suggest I do the wires at the same time or is that overkill? Escape has about 130,000 km's on it.
Old Feb 1, 2007 | 07:28 AM
  #35
tcesni's Avatar
tcesni
Do a search on this site for instructions on changing the spark plugs. Someone previously posted directions with photos and they worked great.
Old Mar 13, 2008 | 10:23 AM
  #36
BII Plow Truck's Avatar
BII Plow Truck
mines say to inflate to 30 psi... needless to say, I run 33-34 psi..
Whoa, DO NOT over inflate your tires! Stick to the specification listed on the label....this is why Explorer owners ran into trouble. The suspension, brakes, and handling are all designed with the specified tire pressure on the label. Any deviation just asks for trouble. If it didn't matter the manufacturers wouldn't spend the money on a label.
Old Mar 13, 2008 | 12:15 PM
  #37
Nitramjr's Avatar
Nitramjr
The Explorer's problem was the tires being underinflated and overheating. The recommended TP on the sticker is mainly based on ride quality. I've found that splitting the difference between the sticker (35 psi on my Escapes) and the tire manufacturer maximum pressure (44 psi) results in no loss of ride quality but measurably better gas milage.
Old Mar 13, 2008 | 12:38 PM
  #38
YoGeorge's Avatar
YoGeorge
Yup, no problem going to the tire max...
If you stay within the tire mfr recommendation for pressure, you're fine, with the major risk being a little more tire wear on the center ribs if they are overinflated a lot. There are a lot of folks who put truck-rated tires on half-ton trucks and vans, and these are 50 lb tires, whereas the stockers were rated at 35-41 lbs max.
Actually, the Michelin 235/75 XL's on my van have a max recommended pressure of 41 lbs, but on the mfr site, they have specific recommendations to increase the pressure somewhere between 1 and 4 lbs or so if you are pushing the higher speeds allowed by the tire.
The sticker is on the door jamb because the govt requires it. Explorers had low pressure recommendations (for a nice ride), and folks would let them run lower than that, causing them to shred (in large part because the tires were also faulty). Ford issued new door stickers with higher recommended pressures.
George
Old Mar 13, 2008 | 12:54 PM
  #39
Nitramjr's Avatar
Nitramjr
I've been watching the tires closely on both of my Escapes and have yet to see any unusual wear at all on any of the tires. After about 30k miles on each one, all tires look great with even wear all around.
Old Mar 13, 2008 | 01:35 PM
  #40
BII Plow Truck
If you stay within the tire mfr recommendation for pressure, you're fine...
No this is incorrect. Follow the vehicle manufacture's label, period. Tire pressure is very critical. They don't spend the money to place a label there for nothing. The government does not 'Require' a tire pressure label unless the suspension was designed with a different pressure specification then the tire maximum pressure rating.
The PSI on the side of a tire is just the MAXIMUM pressure, so the tire mounting tech doesn't overinflate to seat the beads, and so the maximum weight of the tire has a reference point.
Underinflated or overinflated, it doesn't matter....the point is that it's wrong either way.
It's just like overfilling your crankcase by an extra quart of oil, you just don't do it.
Do not risk it, it's an accident waiting to happen with improperly inflated tires. I've know too many people who have skidded off the road due to overinflated tires too hard to grip the road, and many people underinflate and the tire tucks under the rim causing the vehicle to flip in a manuever.
We don't know more than the manufacturer's engineers, there are reasons they design the suspensions this way.
Old Mar 13, 2008 | 01:46 PM
  #41
Nitramjr's Avatar
Nitramjr
Okay, point noted.
I will inflate my tires to the vehicle manufacturers recommendation of 35 psi...±5 psi.
Old Mar 15, 2008 | 09:02 PM
  #42
whdahel's Avatar
whdahel
WOW 16 mpg..... thats what we get in our 98 mountianeer with the 5.0 awd. Wife and I were talking about a lil escape for fuel savings......... Maybe not now. If we get one it would be 4x4.
Old Mar 16, 2008 | 06:25 PM
  #43
ptb6744's Avatar
ptb6744
I am new to this forum and this is my first post, but I just got done changing all 6 spark plugs on my 01 Ford Escape XLS v6 3.0L with 97000 miles. I also changed the oil, air filter, and I plan on changing the fuel filter.
I also have nitrogen filled tires that are around 32 psi. My gas mileage (before the tune up) was 17 in town and 23 on highway.\
Can replacing the oxygen sensors help gas mileage? I am nervous taking them off because they are on there pretty long and are rust and with all the heat there usually makes them hard to take off. If I were to crack the manifold, then I would need to replace all of that too and I do not want to do that.
Old Mar 16, 2008 | 06:26 PM
  #44
ptb6744's Avatar
ptb6744
I agree, I only inflate my tires up to the psi listed on the sticker. I always feel like im going to have a blow out if I over inflate the tires.
Old Mar 16, 2008 | 07:09 PM
  #45
jeffk14's Avatar
jeffk14
I have a new (to me) 06, 4 cyl, 5spd manual XLS. 40K miles. I'm very happy with my hand calculated 28.7 mpg. 70% interstate, 30% city driving. BTW, I run 33 psi front & rear.
