93 F-150 problem with engine cutting off
Old Aug 30, 2006 | 03:28 PM
Whitebread's Avatar
Whitebread
Exclamation 93 F-150 problem with engine cutting off
I have a 93 F-150 5.0 V8 302. I have a problem with it cutting off on me when i stop suddenly or if I'm trying to turn around somewhere tight, like having to back up and drive forward. The engine temp has no effect on it. It does it on hills or flat ground. I've changed out the plugs and wires. The filter has been changed I've also checked the air system for any obstructions. It just got an oil change recently. The cutoffs are starting to become more frequent. Any help would be greatly appreciated.
Old Aug 30, 2006 | 05:50 PM
subford's Avatar
subford
Try cleaning or replacing the Idle Air Bypass Valve and the EGR valves.
Old Aug 31, 2006 | 05:57 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome whitebread, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 31, 2006 | 01:29 PM
Old_Paint's Avatar
Old_Paint
For about $8, you can get a new plenum and throttle body gasket set. Check my gallery for some good pics about what happens to older 5.0's with the high rise plenum. If it's primarily when you're dropping the throttle, sounds to me like it's grabbing excess air from somewhere. It takes about 1 hour to remove the plenum and TB. If you want, this is also a good time to replaced the TPS.
If you think this problem is bad with the auto tranny, try it with the M5OD. It'll make the truck buck, snort, sneeze and try to do reverse wheelies. Mine would buck so bad starting off in 1st, sometimes it would actually chirp the tires when it cut out.
Old Aug 31, 2006 | 03:19 PM
Whitebread's Avatar
Whitebread
Much thanks.
Thanks for the help. I had a feeling it was the throttle body. A buddy of mine had a bronco with the same engine type and he had the same problem as me. Also the pictures are an awesome help. Thanks Old-Paint.
P.S.-What did you use to clean the ports and IAC?
bryanrandall
New Member Introductions
Mar 3, 2015 09:36 AM
Modahl135
Oct 30, 2014 04:35 PM
CrazyMiracleMan
13
Oct 16, 2012 03:35 PM
lostin90s
34
Jul 17, 2006 12:49 PM
Greg Kinkeade
Oil & Lubrication
20
Dec 9, 2005 06:04 PM
