Sponsored by: Real Truck
LSD or posi or open?
Old Aug 30, 2006 | 01:34 PM
fordlovin's Avatar
fordlovin
I have a 01 F250 4x4 Diesel and I was wondering if the rear end or the front end has any type of trac control. If its not standard then is there a way I can find out?
Old Aug 30, 2006 | 01:51 PM
Pocket's Avatar
Pocket
Tag on the differential cover or in the door jam have the code. You can look in the FAQ's and locate the rear end that you have.
More than likely you have a 3.73 limited slip.
