95worktruck
Old Aug 30, 2006 | 05:58 AM
95worktruck's Avatar
95worktruck
95worktruck
Timing problem? High milliage 95 Ford F150 300-6 with 5 spd manual transmission recently had worn-out distributor replaced. Truck ran perfectly with plenty of power (I tow a 16ft trailer) before repair, but afterwards, truck has very lagging power and acceleration. Since the distributor was the only repair, what could cause the power to be off? Mechanic has since checked timing 3 times and says it is set right. Are there other factors to be considered?
Old Aug 30, 2006 | 06:27 AM
EPNCSU2006's Avatar
EPNCSU2006
Check and see if he pulled the SPOUT connector when he checked the timing. If he didn't, the timing is probably not advanced enough, causing sluggish performance.
