HP & Torque
Old Aug 30, 2006 | 12:42 AM
CheaperJeeper's Avatar
CheaperJeeper
HP & Torque
I've searched online, and I bought the only aftermarket manual I can find for my truck (1986, 6.9 liter, C6 tranny) and I have been TOTALLY unsucessful in finding the stock HP & torque output numbers for it.
I looked at the specifications page here on the site, and they don't go back far enough to cover a truck this old. I'm sure someone around here has this info.
So....
What is the peak HP and at what RPMs?
and
What is the peak torque and at what RPMs?
Thanks in advance.
Old Aug 30, 2006 | 12:06 PM
Hamberger's Avatar
Hamberger
6.9= 170HP 315 torque
Also check out the following link for more Hp/Torques of any Ford Truck.
http://en.wikipedia.org/wiki/Ford_F-...2.80.931986.29
Seb.....
Old Aug 30, 2006 | 12:28 PM
CheaperJeeper
http://en.wikipedia.org/wiki/Ford_F-250#Seventh_generation_.281980.E2.80.931986.29
Seb.....
Thanks for the info Seb. I found that Wikipedia link last night by doing a web search. However, it only listed the 170 HP specification, but not the 315 ft/lbs Torque specification. Where did you get that 315 number? Those would be the PEAK HP & Torque numbers, so now I'm getting pretty close to having all the info I'm looking for.
Now I'm just looking for the info on what RPMs the engine produces those peak numbers.
170 HP at ????RPMs
315 ft/lbs at ????RPMs
Can anybody fill in the ???? blanks........
Old Aug 30, 2006 | 01:14 PM
DT 466Man's Avatar
DT 466Man
3300RPM peak HP
1600RPM Peak TQ, should be right.
Old Aug 30, 2006 | 02:00 PM
CheaperJeeper
Originally Posted by DT 466Man
3300RPM peak HP
Thanks Man!
So, from that I'll take it that somewhere in between - presumably around 2000-2100 - should be the point where the HP and torque curves cross, and therefore the optimum RPM range for pulling a load on the highway, eh?
Old Aug 30, 2006 | 02:52 PM
Hamberger's Avatar
Hamberger
Yap,
If you look at the newer 7.3l the overdrive trannies (automatics and manuals) are all geared to a highway cruising rpm anywhere from 1,900 to 2,100 rpm depending on your rear end. The 6.9l motors never had OD trannies so their fuel economy was lower as they cruised around 2,500 rpm.
It all makes sense.
If you want better fuel economy you add an overdrive unit such as a US Gear Splitter or a Gear Vendor unit.
A second OD unit also makes sense on the newer 7.3l trucks to take advantage of the low end torque and save fuel if you don't mind getting where you are going a little slower which is not exactly the way the truck market has gone over the last 15 years. Everybody wants more power and go faster so the fuel economy on a 93 7.3l turbo is still atleast 20% better than what a new 2006 PSD will do. Amazing isn't it.
But maybe the winds are starting to change, Ford seems to be promising higher fuel economy and power on the new 2007 6.4 liter trucks. We will have to see I guess.
Anyway, best of luck,
Seb.....
Old Aug 31, 2006 | 07:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Depending on where you look the HP and torque numbers vary depending on how it was measured.
Bare engine on a dyno, complete engine on a dyno, or rear wheel installed in a vehicle.
guthrie&co
6.4L Power Stroke Diesel
102
Dec 6, 2006 11:40 PM
matthew35
Oct 17, 2006 12:07 PM
SoCalDesertRider
Dec 24, 2003 07:57 AM
TallPaul
4 Cylinder Engines
19
Oct 9, 2002 06:01 PM
TallPaul
18
Dec 2, 2000 10:19 PM
