300 with MAF sensor??
Old Aug 30, 2006 | 12:41 AM
blownstude's Avatar
blownstude
Was there ever a 300 6cyl built with a mass air system? I was told late 96or 97 had them. Never seen it and somehow don't believe it.
Old Aug 30, 2006 | 01:06 AM
desperado_18_2000's Avatar
desperado_18_2000
The 300 did indeed come with a MAF system from the factory for the last year of the 92-96 bodystyle. They are just extremely difficult to find.
Old Aug 30, 2006 | 09:21 AM
crash104936221's Avatar
crash104936221
Yup, my 96 is mas air system. so they are ou there my stepfathers is not mas air but its a 95
his is a 95 F150 XL 2wd 300, m5r2 open 3.08
Old Aug 30, 2006 | 09:48 AM
SR_Crewchief's Avatar
SR_Crewchief
The only EEC-IV/OBD-I application that had MAF/SFI were the 95 California 300's. All 96 EEC-V/OBD-II are MAF/SFI. And 96 was the last year of 300's.
Old Aug 30, 2006 | 10:49 AM
Silver Streak's Avatar
Silver Streak
They still used them in the SD 250 and 350 until the body style change in 99.
Old Aug 30, 2006 | 11:15 AM
blownstude's Avatar
blownstude
Thanks for the replys guys. Would these mass air 300's be easy to tune with a handheld tuner like SCT if I was going to do a turbo setup?
Old Aug 30, 2006 | 02:20 PM
SR_Crewchief
Really? Every reference I've come across states that all 300/4.9 production was discontinued after the 96 model year. I'd be interested in finding a 99 SD250 with the big six in it.
Old Aug 30, 2006 | 02:23 PM
SR_Crewchief
If the program is supported by SCT, then you could with the 96's since they are OBD-II. The 95's being OBD-I are not compatable with the tuners and require chip carriers plugged into the J3 test port instead.
Old Aug 30, 2006 | 03:11 PM
Silver Streak
In the F150 it was. You won't find a 99 with a 300 in it because that was the first year of the new body style in the big truck. They used the 5.4, V10 and PSD. In 97 and 98 the 250 and 350 still had the body style of the 96 and earlier 150. I'm sure those trucks with the 300 are very rare, if they made any. But it was available.
Old Aug 30, 2006 | 05:28 PM
bchunter's Avatar
bchunter
My 96 has a mas air system.
Old Aug 30, 2006 | 05:35 PM
blownstude's Avatar
blownstude
what mileage do you get and do you use it to tow at all? Wondering how much power it has to tow a car trailer with a 3000# race car.
Old Aug 30, 2006 | 06:05 PM
bchunter's Avatar
bchunter
I tow my travel trailer, ~5300 lbs. It is not fast but will get you where ever you want to go. I gotta shift out of 5th on most hills, which is commen sense, but can keep 90 to 100 kph most of the time. I also have 35" tires and 4.56 gears so I have a wee bit more wind resistance then before. I am actually quite impressed on how it tows. I tow a jet boat as well, which would be around the 2000 or so mark and the truck does not even feel it behind. Alot depends on your tranny and gears, but I say hook up to it and go for it. If you have the right tranny / gear combo, I think you will be suprised at what it can do. I know I was.
Old Aug 30, 2006 | 06:06 PM
bchunter's Avatar
bchunter
Oh, sorry, for milage I am getting 16 mph empty and never figured it out with the trailer, but would be around 12 I would guess looking at my consumtion.
Old Aug 30, 2006 | 06:29 PM
SR_Crewchief
Sorry, ment 98 not 99.
I agree that the 250/350 retained the 9th gen chassis in 97 and 98...what I find when searching is that the Essex 4.2 V6 replaced our 4.9/300 I6 and that the Triton series V8's replaced the Windsor series in the 97 model year.
Perhaps there were a few 250's assembled with the I6 for "leftover" stock the same as some of the 80-81 I6's had forged cranks from leftover stocks from the HD's. Finding one would be rare and worth hanging onto.
Old Aug 30, 2006 | 07:51 PM
blownstude's Avatar
blownstude
bchunter what tranny do you have and I am assuming your rear is 4.56?
