engine swap
Old Feb 16, 2002 | 12:16 AM
direwolf52's Avatar
direwolf52
Post engine swap
I have a 1961 F500 with a blown 292.I just got a 360 with tranny. My question is, can I drop the 360 in and use my existing tranny and mounts? If not what do I need to switch? Thanks Direwolf
Old Feb 16, 2002 | 01:48 PM
cobraguy's Avatar
cobraguy
engine swap
[updated:LAST EDITED ON 16-Feb-02 AT 02:51 PM (EST)]You forgot to tell us what trannys your working with. If both are the same it will probobly work assuming your talking about the tranny mounts being on the bellhousing. You'll have to make or buy engine mounts or an engine crossmember for the 360 into a 61. Let me know if we're barkin up the right tree. The 360 won't bolt up to the 292 bellhousing, but if the 360 bellhousing has mounts on it they might fit the 61 crossmember.
Old Feb 16, 2002 | 08:00 PM
airharley's Avatar
airharley
engine swap
The 292 engine has a front mount vise the side mount on the 360. You will end up buying an adapter mount for the engine or fabricate your own. Look in LMC or Dennis Carpenter for the mount kits.
Old Feb 16, 2002 | 11:28 PM
TKONO's Avatar
TKONO
engine swap
1966f100ranger
May 28, 2017 12:54 PM
TStarr5976
Dec 12, 2012 09:29 PM
rlbrain
Apr 12, 2011 02:18 PM
ColodadoFordBoys
28
Jan 23, 2009 02:46 PM
txen
May 8, 2007 01:39 AM
