Starting and stalling
Old Aug 29, 2006 | 06:07 PM
SRatta's Avatar
SRatta
Unhappy Starting and stalling
Hi all,
I just joined this web site, I have a 99 EB expedition with the 5.4, I have been reading many of your post and it looks like you have a great wealth of knowledge here, already I have found many interesting topics with solutions. Great material!!
The problem I am having with my expedition is that on occation when I start the truck it stall after running a second or so. The only way to keep it running is to keep my foot on the gas a bit and drive it that way using the brake until it warms up a bit then it is fine and this problem may not re-occur for a month. I have read posts that may have some relation, IAC valves, Mass Flow sensor?
I have replaced the fuel filter, PCV valve and 7 of 8 plugs 2 of which we very loose. (did not even need a rachet to remove). Truck now runs great must have been loosing compression fron the loos plugs, even the coil boots were burned, I though That may have been the issue but now about 1 month later it has happened again.
Thanks in advance for your help
S.Ratta
Old Aug 29, 2006 | 07:09 PM
chopper269's Avatar
chopper269
Had the same exact problem with my '00. Took care of it by replacing the IAC valve. Never had the problem again.
Old Aug 29, 2006 | 08:31 PM
Gervis's Avatar
Gervis
Problems with vacuum lines may also cause this issue. My bro ran in the same stalling problem and found out that the fuel pump needs to be replaced
Old Aug 30, 2006 | 05:36 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome SRatta, to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 30, 2006 | 08:25 AM
SRatta's Avatar
SRatta
IAC Valve
Thanks for the feedback, I think I will start with the IAC valve, I just dont know what it looks like, or where it is, I would like to try cleaning it before I replace it, If I get any improvement then I will replace it. What should I use to clean it? Is Gumout too harsh or should I just use alcohal?
Thanks
S.Ratta
Old Aug 30, 2006 | 08:46 AM
Mr.Novice's Avatar
Mr.Novice
This is the IAC on the 5.4L:
Great instructions on how to change it out here:
https://www.ford-trucks.com/forums/1...picture+of+iac
If you're going to clean it, use carb cleaner.
Old Aug 30, 2006 | 10:41 AM
Darth Baiter's Avatar
Darth Baiter
Thanks
S.Ratta
Do a search on IAC or Idle Air Control Valve. There are many threads, some with pictures. Cleaning seems to work, for awhile but not forever. Replacement may be the best solution.
Appears Mr. Novice types faster than I or his system access isn't as slow as mine is. Good post.
Old Aug 31, 2006 | 05:38 AM
SRatta's Avatar
SRatta
Red face
Thank you all for you help, You Guys ROCK!!!,
Illustrations are great, Hope I can help with something in the future.
S.Ratta
scottss80
Escape & Escape Hybrid
Feb 7, 2013 08:29 AM
SRatta
Jan 8, 2010 04:16 PM
SRatta
2004 - 2008 F150
Nov 3, 2006 06:42 PM
tlk401
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 25, 2006 08:12 AM
Spank
1983 - 2012 Ranger & B-Series
13
Apr 5, 2004 11:23 PM
