strange noise up front
Old Aug 28, 2006 | 09:44 PM
weightset's Avatar
weightset
Today when i was leaving from work i noticed a really loud squeaking noise from up front when i turn the wheel or when i hit bumps. I have had many leads on what it may be but not sure. I have been told maybe the lower ball joints and others are saying the steering pump need some help asap thanks
Josh
Old Aug 29, 2006 | 06:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 29, 2006 | 07:50 AM
sfcwoodret's Avatar
sfcwoodret
It may just be the steering pump pulley belt.
Old Aug 29, 2006 | 10:10 AM
weightset's Avatar
weightset
the noise is coming from the passenger side front tire
Old Aug 29, 2006 | 10:25 AM
matt's2.9STX's Avatar
matt's2.9STX
It does sound like a ball joint. Same thing with my Dad's 95 Crown Vic. His are "lifetime" greased & garage said thier still ok for now. Pop the truck up in the air & check for wheel slop. Put a big lever under the tire & pry up. Try to watch the mechs behind the tire.
Old Aug 29, 2006 | 11:01 AM
fordboy_52's Avatar
fordboy_52
welcome weightset! Im glad you chose the best site on the net for ford trucks, see you around!
Matt
Old Aug 29, 2006 | 05:20 PM
customstringer's Avatar
customstringer
I might suggest you post some more information about your Ranger or B, year, mileage, engine, transmission [manual vs. auto], for example, to help further narrow what your front end noise could be. For example there can be a big difference in the engine, steering and suspension components depending simply on the year of the truck and whichever engine. The more specific you are the more help you may get. Just a thought.
