1978 - 1996 Big Bronco
T-case still leaking
Old Aug 28, 2006 | 01:36 PM
wileec's Avatar
wileec
I had o bad rear seal pulled the old one oiled the new seal and the sleve seems like it seated corectly but is still leaking. What am I missing?
Old Aug 28, 2006 | 05:57 PM
MatthewC's Avatar
MatthewC
Were there little chunks out of the old seal when you took it out? Were you absolutely sure that the t-case housing where the new seal went in was free of debris/pieces of old seal?
Old Aug 28, 2006 | 06:21 PM
chrono4's Avatar
chrono4
was the shaft rough, or scared up from somthing? try changing it again, use a light coat of silicone on the seat of the seal, and use a ruber mallet to put it in. also, take some emory cloth to the shaft, clean it up really good, and when its all together, put some light oil on the seal so its not spining dry until it gets oil.
Old Aug 30, 2006 | 06:51 PM
dwoodler's Avatar
dwoodler
Are you sure it was at the shaft maybe it was the speedo gear or the tail housing?
Tuna Maniac
Mar 6, 2017 02:32 AM
ManfredVonRichtofen
Sep 12, 2016 04:05 PM
2020
May 30, 2015 09:13 AM
bamaboy_1966
1961 - 1963 F100 Unibody
Oct 5, 2014 09:08 PM
atlanta1020
Aug 3, 2012 06:47 PM
