Weird Timing Problem
Old Aug 30, 2006 | 10:54 AM
zzzzzz's Avatar
zzzzzz
what about the 10 cent roll pin that holds the gear to the shaft any play with that if its loose it could change things?
Old Aug 30, 2006 | 11:09 AM
Fritolay's Avatar
Fritolay
the shear pin rarely gets loose it is typically in one piece doing its job or broken. if broken it is highly unlikely the truck would run at all.
Old Aug 30, 2006 | 02:01 PM
1975Ford's Avatar
1975Ford
wagner is popping a new distributor, that's covered.
Old Aug 31, 2006 | 08:45 PM
it.wagner's Avatar
it.wagner
Smile
Final Update:
Put in the new dizzy & plug wires (just for good measure) and fired her up....
Sounds Beautiful. Vibrations are gone, thanks for all the info and suggestions.
Old Sep 2, 2006 | 10:54 AM
1975Ford's Avatar
1975Ford
Good job, thanks for posting results.
pit_of_pity
33
Sep 26, 2013 06:13 PM
topfile
Aug 12, 2012 10:33 PM
pit_of_pity
Nov 10, 2010 10:33 PM
Argess
16
Jul 19, 2009 12:13 PM
