Offroad & 4x4
body lift
Old Aug 27, 2006 | 06:44 PM
kjg26's Avatar
kjg26
body lift
with a body lift do i have to brace the bed at all? i remember having to do something to reinforce the bed. will the weight i can carry in the bed go down? worry about collapsing the bed? any worries at all? i'm thinking about doing a 2 in performance accesories lift.
thanks
keith
Old Aug 27, 2006 | 06:53 PM
YoungMT Hick's Avatar
YoungMT Hick
ok first what you need to do is state what kinda truck you have that will help. i put in a 3" body lift on a 75 ford and i have no worries. you will get a gap between the rear bumper and the front bumper will not fit unless you make bumper brackets. it will help knowing what truck!!!
Old Aug 27, 2006 | 07:27 PM
kjg26's Avatar
kjg26
sorry. on the other forums i'm on i have a sig that has all my info. it's an 89 f150 reg cab long bed 4x4, it has custom bumpers so the bumpers will fit.
Old Aug 27, 2006 | 07:45 PM
chrono4's Avatar
chrono4
youngmt, hover your mouse over the "signature" button, it tells you the there stuck.
Old Aug 29, 2006 | 02:37 PM
YoungMT Hick
i see it now. thanks. but ya if you have custom bumpers it will work the lift might come with bumper brackets if it is that age maybe . you will have to check into that
Old Aug 29, 2006 | 05:07 PM
RawPower's Avatar
RawPower
yes, safe load capacity will drop.
just cut the fenders out, you'll be much happier later if you do it right
Old Aug 29, 2006 | 08:09 PM
kjg26's Avatar
kjg26
how would you suggest cutting the fenders out? innter fenders? or just trimming the outter fenders? any pics of suggestions?
Old Aug 29, 2006 | 08:49 PM
RawPower's Avatar
RawPower
i dont know about your inner fenders, but on some trucks you have to get rid of them and replace them with something else, but some are good to go. You would deffinately hack the outer fenders, for you application maybe only 1 or 2"
Or perhaps a better easier idea for you would be to just get some coil springs for the front that are 2" taller than stock... that would cost around what a body lift would.
Old Aug 29, 2006 | 09:40 PM
kjg26's Avatar
kjg26
what would i do for the back
Old Aug 30, 2006 | 09:37 AM
74fordtruck's Avatar
74fordtruck
A lift block, add-a-leaf, or a shackle flip would take care of the back, and could be had for free to a little more than free. Either way, it's better than the headaches of a body lift, and 100 times easier to install.
The front I proabably wouldnt do without a kit with drop brackets for the TTB though. Cuttouts are easier
Old Aug 30, 2006 | 11:49 AM
fishmanndotcom's Avatar
fishmanndotcom
now a 2" body isnt too bad considering what kind of driving you plan to do. if i was you i'd maybe do a 1" BL and then trim what was necessary.
with a 1" BL you could get some 1" thick plate and shim the space b/t the bed and frame. should be as good as stock
-cutts-
Old Aug 30, 2006 | 01:08 PM
kjg26's Avatar
kjg26
i can't find a 1 inch kit ANYWHERE. everyone has 2 inch kits. i still don't see what your saying to trim. i got the outter fenders. the sheet metal around the wheel well. but what about the inner fenders? the body lift from performance acc. comes with some square tubing to brace the bed.
Old Aug 30, 2006 | 09:45 PM
kjg26's Avatar
kjg26
will someone please describe to me what i have to do to do a shackle flip on my truck. alink to a writeup would be great.
thanks
keith
Old Aug 30, 2006 | 10:12 PM
chrono4's Avatar
chrono4
not sure on a write-up on it, I'll be doing mine this weekend. I'm lowering my spring towers 2-2.5 inches, removing the rear add a leafs and doing a shackle flip, I figure this should level it out pretty good. I plan on getting lotsa pictures, and writing the whole thing up next week.
Old Aug 30, 2006 | 10:20 PM
kjg26's Avatar
kjg26
when you say shackle flip what does that intale?
