Accelerator Cable
Old Mar 10, 2002 | 05:10 PM
monroemike's Avatar
monroemike
Accelerator Cable
I recently bought a 1966 f100 Custom Cab Long Bed. The original engine had been replaced with a 289. I replace it with a 351W. My problem occur the other day when the accelerator cable broke. I purchased an original (20 inches long) from Dennis Carpenter which did not work because it was too long. Can anyone tell me of an accelerator cable from a different model that will work.
Thanks
monroemike
Old Mar 10, 2002 | 06:03 PM
6t6merc's Avatar
6t6merc
Accelerator Cable
The Ford part is still available at your dealer.It's pretty expensive though, $70 in Canada.
Eric
Old Mar 10, 2002 | 06:43 PM
monroemike's Avatar
monroemike
Post Accelerator Cable
The original did not work. It was too long. What model had a shorter cable
Old Mar 10, 2002 | 06:56 PM
jowilker's Avatar
jowilker
Accelerator Cable
Mike the length of the cable doesn't matter. You can make a 40" cable work. It is how you clamp the cable in the mounting bracket behind the carb that is the key.
BTW you share the same last name as my mother.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Mar 10, 2002 | 07:02 PM
monroemike's Avatar
monroemike
The twist is too sharp to have free movement in the cable with the 20" cable. A longer cable will be unsitely. I'm trying to get the best look possible.
hollibau's Avatar
hollibau
Accelerator Cable
Monroe,
I had the same problem recently. I went to a local yard and pulled the pedal assembly and various rods from three different trucks and did away with the cable junk (11 bucks for the pedal assemble rods were free). I have had two cables break, one on a different car and this one, luckily I was close to home both times. I never had a rod break yet. You will just have to experiment with different rod lengths and how they are bent, but it is an easy fix and I doubt you will ever have to worry about this again.
Ttake care,
Mike
Old Mar 12, 2002 | 11:03 AM
bk_66's Avatar
bk_66
Accelerator Cable
If you still have the old parts,
use the old sleeve and thread some new aircraft cable (wire rope) through. It helps to carefully cut the tip down to a point and wrap it with a small bit of tape to get the cable through. Then use your old attachments/cable attachments. I used the round eyelets on one end and the cut connection off the old cable to hold it on.
Too long a cable is not necessarily good. the replacement than I paid several $$ for broke after about 2 years, part of which I attribute to tool long a cable forced into the original guides. (also made the accelerator stiff)
Old Mar 12, 2002 | 11:32 AM
airharley's Avatar
airharley
Accelerator Cable
I went to Napa Auto Parts and picked up 2 ball joint fittings and 3 feet of 5/16 threaded round stock. I fabricated mine out of that to replace the cable (really it was a coat hanger). Cost me less then $15.00 (ball joints were $6 a piece) Now I know it wont break when I pound the gas in. Plus I can adjust my throttle linkage any way I want to now. Are you running an aftermarket carb or the stock one? Mine is a Holley.
Old Mar 12, 2002 | 09:10 PM
LxMan1's Avatar
LxMan1
Accelerator Cable
My 63 F100 has a rod not a cable. It is factory. It works fine with my 351W/ Edelbrock performer intake and 600 Holley carb. You may also look into the pedal rod assemblies from a mid 70's Ford truck.
Jimmy
Old Mar 13, 2002 | 09:26 AM
truckfarmer's Avatar
truckfarmer
They made 2 different cables for the 66's. I think the V8 was shorter than the 6 cylinder cable. Ask your favorite vendor, like the one on this site.
Old Mar 14, 2002 | 06:45 PM
monroemike's Avatar
monroemike
Accelerator Cable
Thanks guys. I think I will try rods. Going to the junk yard tomorrow.
monroe mike
Old Mar 15, 2002 | 11:10 AM
Brian's Avatar
Brian
Accelerator Cable
I have the shorter V8 cable in my 66 with 351w and it seams to work fine. I am using a cable clamp arrangment off a FE to hold the cable.
Old Mar 16, 2002 | 12:07 AM
deronyv8's Avatar
deronyv8
Accelerator Cable
