Sponsored by: Auxito
Gear Selector Adjustment Broken
Old Aug 27, 2006 | 03:01 PM
Ithaca's Avatar
Ithaca
Hello all,
Lets Open by a big THANK YOU for all the money you are saving me on a rainey Sunday in Ohio. Two of Three problems are already posted and solved. My current problem is with my gear selector. My mechanic (for the big problems) showed me how to adjust the selector. It slipped the other day and now woln't adjust. It appears the white plastic carrier barcket on the column is busted. How involved is this going to be. I'm an Okay mechanic, but some times can suffer from lack of patience and tolerance in these projects. The low down on the truck. 1999 F-250LD (7700),Automatic Trans with manual 4x4 selector 5.4L motor, Standard cab long wheel base. Please help. It's not a big issue but makes me crazey(-ier) to see that dang thing out of position. Thank you in advance.
Old Aug 27, 2006 | 10:41 PM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
To replace the broken piece you'll have to replace the complete shift indicator and cable assembly.
It's actually pretty easy to do.
You'll have to remove the covers on the steering column (screws on the bottom side and remove the ignition lock cylinder by putting the key in Run and pressing the little button under the lock cylinder with a small screwdriver or pick to release it.) and the one above the column, under the instrument cluster (it just pops off).
Once you've got the covers off there are just a couple clips holding the shift indicator into the instrument cluster. The other end of the cable is just a loop that goes over a hook on the lever from the shifter.
It's probably easier to do the job than explain it
Old Aug 28, 2006 | 12:00 PM
Ithaca's Avatar
Ithaca
Thank You. I was apprehensive about getting into linkage adjustments and way to deep to fast.
Old Sep 4, 2006 | 12:09 PM
Ithaca's Avatar
Ithaca
Finished this project this AM. Went flawless except for that "one" bolt that always is able to leap to its death in to the dash abyss. I got really brave and fixed the odometer problem to. $45.00 later and all my problems are gone for now. Thanks Racerguy for the info. Next wil be the door locks. Thanks again
motorcarmike
Feb 13, 2016 06:03 AM
czaker
22
Sep 22, 2015 08:00 PM
DrZoom
May 18, 2015 03:27 PM
DynaMow
Sep 7, 2014 11:07 AM
rews2
Mar 27, 2014 06:25 PM
