Sponsored by: Kumho
Front brakes
Old Aug 27, 2006 | 09:14 AM
wagntwister's Avatar
wagntwister
Question Front brakes
I will be replacing my pads and rotors on my 04 250 5.4l. Disc brake quite for the rear of the pads and is never sieze good for the caliper slides or should I use something else?
Old Aug 28, 2006 | 08:15 PM
2000Ford2000's Avatar
2000Ford2000
Huh? No habla Jenglish.
Old Aug 29, 2006 | 09:22 AM
buzzbait65's Avatar
buzzbait65
I cant understand what you wrote either
Old Aug 29, 2006 | 09:55 AM
chrono4's Avatar
chrono4
I wouldnt be name calling, just starts trouble. You need to type your words more clearly, only thing I caught in your post was somthing about front brakes.
Old Aug 29, 2006 | 10:17 AM
stuart1's Avatar
stuart1
Any form of brake quiet is ok for the rear of the pads.
It is a special grease for the caliper slides.
Old Aug 29, 2006 | 12:34 PM
MScotty's Avatar
MScotty
The high pitched noise is usually caused by the pads vibebrating, not by the pads making contact with the rotor.
There are compounds that you apply to the backing plates that are suppose to stop the noise. Also stick on shims, but they start to slide off and get stuck between the caliper and rotor.
Old Aug 29, 2006 | 10:14 PM
CrazyAirman's Avatar
CrazyAirman
Never use Anti seize on brake parts!!!!!! It cannot handle the heat, and will just run off. Use a good caliper grease, most places have it REALLY cheap, and its designed for the high heat.
Old Aug 30, 2006 | 04:57 PM
2000Ford2000
Ahh! Anti-sieze. Now his post is making some sense.
Old Aug 30, 2006 | 09:31 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Any grease base product even "high temp" will attract dust and dirt to grind things up. For many years (25 plus) I have used dry film Moly spray at every pad change. No pads hang up or stick and drag. JMO on what works for me.
.....=o&o>.....
BBsound
Sep 23, 2016 07:43 PM
perryg114
Aug 2, 2013 06:31 PM
monkey nutz
May 12, 2006 10:39 PM
T0DD
22
Sep 19, 2004 09:18 PM
MustangGT221
May 11, 2003 09:09 PM
