help needed asap on rocker arm problem
Old Aug 27, 2006 | 02:01 AM
roger dowty's Avatar
roger dowty
I got my kids windsor rebuild running- my first....however...
it recently came to me to recheck rocker arms and sure enough my roller tip rockers are not even close to being centered on the valve. They extend to far to the outside- and it does not approach center when compressed- makes good contact with valve tip but not square- it will run but wondering what damage i will do if i break the cam in while waiting for 1.6 rockers and the right pushrod measuring tool. I have two- one short and one long.
For reference i have an 84 block- '65 289 heads with 3/8 stud. The rockers are pro-comp 1.7- take off of comp magnum roller tip.
a guy is helping me tune and break it in in 9 hours so input is appreciated- especially as to the risk of running it for a half hour or so. I'm in a tight window to have the help.
also- i went with the stock cam and with the heads I'm at 9:1 CR- one of the reasons I went with 1.7 rockers was to get a bit more lift- maybe I just need to focus on the right push rod length??
thanks
Old Aug 27, 2006 | 06:19 AM
ken75ranger's Avatar
ken75ranger
Your last thought is right. All you should need is a different lenght pushrod. Summit carries pushrod checkers. Then you can dial in the right lenght.
Old Aug 27, 2006 | 08:38 AM
P51D Mustang's Avatar
P51D Mustang
I know you don't want to hear this, but don't run the engine for break in until you get this sorted out. It will damage the valve guides rather quickly.
Old Aug 27, 2006 | 02:42 PM
roger dowty
yea, i quit the process- will order in some 1.6 rocker arms- that should get it straight.
surpised they don't offer pushrods to match the 1.7 given that they sell them. that .1 should pull me right in line I'm thinking.
htownoag
17
Oct 19, 2015 10:47 AM
lannondiesel
Oct 14, 2014 06:12 PM
278broncos
25
Sep 13, 2004 11:43 PM
TOUGHY17
Nov 6, 2001 10:27 PM
