dont know about the banks system but the ats is adjustable BUT the linkage is staked or crimped so it wont move. Requires the removal of the adjusting rod from the clevis and running a tap thru the theads to remove the stake or crimp.
the ats system is 3 full turns to make one more pound of boost. dont want to over do this either ... too much boost will lift the heads.
The wastegate lets exhaust gasses bypass the turbo after a predetermined amount of boost is produced. Shortening the wastegate rod raises the amount of boost the turbo will produce before the wastegate opens.
I will also recommend you be running both a boost gauge and a pyrometer before you do this.
More boost, more heat, more power = possible head gasket damage or piston damage without a way to monitor what is going on inside the engine.
Also the rod that goes into the wastegate actuator must not be allowed to turn or the diaphram will be torn.
The 6.9 has 7/16" head bolts. If it has the original head gaskets and over 100,000 miles I would stay under 10 PSI.
The 6.9 had 22.5 to 1 compression to start with, 10 PSI of boost gets it up to 37.8 to 1.
Stock boost on the 7.3 turbo was in the 7 or 8 PSI range, and it has much stronger 1/2" headbolts. The 7.3 had 21.5 to 1 compression and 8 PSI gave it 33.2 to 1 compression ratio.
If you want to run 20 PSI boost on a 6.9 you will need a lot more work than a boost gauge and pyrometer. New head gaskets and head studs would be the minimum to get close to 20 pounds boost reliably.
you think 15psi boost on a 6.9 with new head gaskets and head studs would be safe? and how would i tell how much boost im adding when adjusting the wastegate rod?
Install a boost gauge and pyrometer.
Boost gauge line taps into the intake manifold piping.
The best place for the pyrometer thermocouple is the exhaust manifold.
That way you can see what you are running for boost and keep an eye on how hot the EGT's are, that can save you from melting the pistons.
New head gaskets and ARP headstuds will let you run 15 PSI without any worries.
