valve cover gaskets
Old Oct 14, 2006 | 07:55 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Rubber gasket with contact cement to Cal Custom covers, Hylomar HPF between gasket and head. Haylomar stays soft so gasket can be removed.
Dry valve covers at 248K miles.
Old Nov 13, 2006 | 04:52 PM
rusty70f100's Avatar
rusty70f100
I've had the best luck with cork gaskets. Installed dry, with only a little sealant where the intake meets the head (on a 390). Dont over tighten and let 'em do their thing.
Old Nov 13, 2006 | 05:58 PM
Blurry94's Avatar
Blurry94
I've been using (and re-using) the Ford rubber/steel core gaskets, and they have never leaked.
Old Nov 13, 2006 | 07:14 PM
"Beemer Nut"
I found over the years that to keep cork gaskets leak free is to check the torque, use a extension on the socket and hand tighten once every few months. Yes cork compresses over time with heat to a point you can unscrew them cap screws with your fingers. Rubber gaskets, install, retorque in a month and forget. forget is something easy to do.
chiefsfootball
34
Dec 26, 2018 05:45 PM
kegger66
22
Jun 30, 2016 11:16 PM
Cody LaFata
Jan 7, 2016 07:14 AM
SoCalAngler
37
Apr 22, 2014 08:46 PM
dustinova
May 4, 2007 11:38 PM
