no heat
Old Aug 26, 2006 | 04:35 PM
Jack-USAF's Avatar
Jack-USAF
no heat
Ok about 4 months ago I had to replace my water pump and now it only blows cool air. Before the change that heater would blow me out the truck. See there is a big problem with this, I now live in Alaska so I need this fixed ASAFP. Any suggestions or input will be greatly appreciated. All the vents and selecters still work. It is a 1988 F-150 4x4 with 302 and auto tranny.
Old Aug 28, 2006 | 07:52 PM
Ultramagdan's Avatar
Ultramagdan
Have you checked to make sure the coolant is flowing through the hoses? If coolant is flowing the hoses will be hot.
Old Aug 28, 2006 | 08:03 PM
Jack-USAF's Avatar
Jack-USAF
Yeah I checked to make sure there was enough coolant and the hoses are hot.
Old Aug 28, 2006 | 09:00 PM
Ultramagdan
If your temperture control is working then you may have a pen or some other item that has fallen down the vent and is keeping the blend door from closing.
Old Aug 30, 2006 | 01:09 PM
Holmesuser01's Avatar
Holmesuser01
Wink
Your heater core is probably air locked. Remove a hose and run water from a garden hose through it until the air bubbles out. Its a typical problem.
alaska F 250
6.4L Power Stroke Diesel
16
Nov 21, 2010 08:12 PM
thbowen
22
Feb 20, 2008 09:05 AM
jbkma
Jun 17, 2007 06:49 PM
dmi
New Member Introductions
Aug 24, 2004 03:45 AM
Frosty Ford _Alaska
User Gallery & Picture Display
Mar 13, 2002 10:32 PM
