Tire and wheel question
Old Aug 26, 2006 | 12:40 PM
Billholthues's Avatar
Billholthues
Hello All!
I was wondering what width of rim I should run with 305/70/16 tires. Should I use a 16x8 or a 16x10? I appreciate the help.
Bill
Old Aug 26, 2006 | 02:48 PM
Monsta's Avatar
Monsta
Sit. Stay.
I've always thought the 10" rim is best for tire sizes over 300. Usually the tire manufacturer will give the recommended wheel width for thier tires, though.
Old Sep 1, 2006 | 07:11 PM
Pickupmanx2's Avatar
Pickupmanx2
I have run those w/stock rims, way to narrow, real squishy wobbly feel, I would probly go with 10's, then you can always go bigger in the future!
Old Sep 1, 2006 | 08:46 PM
jhooch's Avatar
jhooch
That tire is specified to be on a 9.0 inch wide wheel. Variants show as a 8.0 or 9.5. Since virtually nobody makes a 9.0 inch wheel, you could use either 8.0 or 10. I would probably use the 8.0 since the 10's will exert more stress on lower ball joints, wheel bearings, etc (they typically will have about 3 to 4 inches backspacing). On the flip side, the tire will probably have a flatter footprint and wear better on the 10. The long and short of it, the 305/70R-16 is kind of an oddball size and may end up obsolete at some point.
Jeff
greentruck72
Feb 27, 2015 01:47 PM
pintoches
Apr 8, 2012 06:18 PM
EMC V10 X
Jul 18, 2011 03:44 PM
zarillus
Sep 20, 2004 03:45 PM
Viper1837
Dec 12, 2003 07:10 PM
