temperature guage erratic
Old Aug 26, 2006 | 10:04 AM
96expblk's Avatar
96expblk
82 f100 4.9 inline 6, automatic. Before having engine rebuilt, the temperature guage would rise to where it looked like it my become hot and then the guage would fall back to normal. Then it would happen again. I did have the engine rebuilt and they found that the head at a crack in it. I don't know if this caused the erratic behavior or not. On the left side of my engine in the block toward bottom there looks like to me a sensor of some kind screwed into the block but there was no wire connected. What reads the engine temperature to send to the guage in truck ?
Old Aug 26, 2006 | 02:54 PM
SR_Crewchief's Avatar
SR_Crewchief
That one is for the oil pressure. Block temp is on the righthand side below and slightly behind rear exhaust manfold. The is also a temp sensor in the thermostat housing for the computer to read(if your efi).
Old Aug 28, 2006 | 12:37 PM
Rosie's Avatar
Rosie
I had this same problem until I replaced the water pump and all hoses. The problem went a way. I dont know if it they are related.
Old Aug 28, 2006 | 01:30 PM
96expblk's Avatar
96expblk
I really meant the left side of engine looking from the front. Sorry. I have replaced water pump, hoses, thermostat, just had engine rebuilt, and now when I ran engine to break cam in, the temperature guage doesn't register at all. I tested the thermostat in boiling water. It was ok. I do have a sensor on thermostat housing so I guess I have efi. Should the temp. sensor on the passenger side in the block also be connected with a wire or will the one on the thermostat housing be enough? I'm not even sure if the 82 f100 4.9l has a computer. I do know it has a Duraspark 2 mounted on drivers side fender well.
Old Aug 28, 2006 | 04:04 PM
96expblk's Avatar
96expblk
As Ray Stevens says "its me again Margaret". I finally figured out what efi stands for and I don't have it. I have carb. system. So I guess what I thought was coolant temperature sensor that was screwed into thermostat housing is actually what is called a "ported vacuum switch" . It has 4 vacuum lines going off of it. How dumb do I feel. So this means that the temperature switch is indeed on the passenger side. I found it but there is no wire attached to it. I'll have to locate the wire that is supposed to go there. Then maybe my temperature guage will work. Thanks for the help anyway.
KICKEDBACK
Jul 31, 2011 12:49 PM
FORDNUT23
Apr 18, 2011 04:26 AM
Frozen001
Aug 15, 2010 08:48 AM
Racer944
Jul 27, 2004 02:32 PM
cchev
1978 - 1996 Big Bronco
Jan 15, 2003 05:39 PM
