Need help adjusting rocker arm
Old Aug 25, 2006 | 06:36 PM
1982fordf100's Avatar
1982fordf100
I need some help adjusting my rocker arms on my 82 F100. I have the 5/16 pressed in studs. The problem is I had a cracked rocker arm boss when I had the head rebuilt. The machine shop had it welded, and replaced that single stud with a screw in 5/16 stud. The problem is the threads on the top of the stud are about 1/8 of an inch longer than all the others. If I torque the nuts like the book says 17-23 ft lbs it bottoms out that lifter. I know all the other rocker arms are not adjustable. What about this lone rocker arm stud? Is it adjustable and how do I adjust it so I can get the desired .125 - .175 valve to rocker arm clearance with the lifter bottomed out and not have the nut back off? Thanks
Old Aug 28, 2006 | 12:36 AM
hoxiii's Avatar
hoxiii
Use a second nut as a jam nut on that stud. Run the first nut down to zero lash+3/4 turn and then lock it up with the other nut. If you need the rocker to go down further, just put a 3/8 washer under the nut but over the pivot.
I converted my entire 5/16 press in setup to be adjustable with this setup and haven't had an issue yet (2 years). I'd recommend converting your whole valve train because after i rebuilt my head torquing the nuts over tightened about 1/2 of teh valves and under tightened the other half. Now i just set them all to 0+3/4 and it runs smooth as can be.
Justin
Old Aug 28, 2006 | 05:18 PM
1982fordf100
Thanks for the help I will use the jam nut on that stud. I figured that was the correct way going about that. I just wanted to make sure. Thanks again.
