oil dye
Old Aug 26, 2006 | 09:58 AM
Hiflyer746's Avatar
Hiflyer746
oil dye
What is the dye used in oil to pinpoint leaks? Whats the procedure? Thanks
Tim
Old Aug 26, 2006 | 10:30 AM
BowTieHatr's Avatar
BowTieHatr
all it is is a uv material in liquid form that can blend with the oil and be carried with it. therefore if you have a leak it will come out with the oil. depending on the leak it may take a while. then it is checked with a uv or blacklight to trace down the leak
Old Aug 26, 2006 | 10:40 AM
Kwikkordead's Avatar
Kwikkordead
What BowTieHatr said. When you use the black light to light up the UV dye it makes the dye glow and is very easy to see where it's coming from. I've used that method before a couple of times when I had a head-scratcher of an oil leak and it leads you right to the source.
Old Aug 26, 2006 | 10:42 AM
Kwikkordead
You can get the dye at NAPA
