I've been on a search to find out what the codes on by 2004 F150 door sticker mean. Hope someone here can expose the hidden secrets (Lariat, w/ tow pkg. 4x4)
R: T (?)
Axle: B6 = (3.73 LS)
TR: B (?)
SPR: UM (?)
of the several available letter codes for the Transmission, "B" wasn't an option - would this be the 4R100 maybe. Don't really care about the Spring Code at this point. The truck does have the new 5.4L, 24valve engine.
thanks,
R: T Radio Code: Premium electronic AM/FM stereo with compact disc (CD) changer and clock
Axle: B6 = (3.73 LS) Correct
TR: B Transmission Code:4-speed automatic, 4R75E
SPR: UM Spring Code: missing info... **Front Springs: Base part number — 5310 **Rear Springs: Base part number — 5560
Off to the right side of the "SPR", there should be 2-lines of 5 characters each. Throw those out and I can give you your Powertrain Calib. Info.
99Triger3_0, I just added the a pic of the whole sticker to my Gallery, in case you care to look it over. By the way, is there a website out there that has all this info?
