Unexplained Chime
Old Aug 24, 2006 | 09:20 PM
IM1096's Avatar
IM1096
Unexplained Chime
I've encountered a "chime" that is coming from under the dash near the e-brake pedal. The chime only occurs after the truck has been started and running for approx 30 seconds and then stops after approx 60 seconds. The chime sounds like when the door is open with the keys in the ignition, only it is barely audible. I searched for about 30 minutes before I finally found where it was coming from. The PCM is located near the brake pedal, does the PCM make any warning noises? My SuperChips tuner shows no codes,,,,, I'm baffled. Any ideas??????
Old Aug 24, 2006 | 09:36 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If I were to guess I'd say your ignition switch is trying to get a short in it.
Old Aug 24, 2006 | 09:37 PM
IM1096's Avatar
IM1096
I should also mention that the truck is running great, no problems.
Old Aug 24, 2006 | 09:48 PM
Uzumati's Avatar
Uzumati
Diodes will squeele when they are dying, next time you hear it check the BJB under the hood and see if it is louder. The front 2 outboard "Fuse" slots are diodes. could be a diode on the board of the PCM but I would expect idleing/running issues.
Old Aug 24, 2006 | 09:59 PM
IM1096's Avatar
IM1096
I checked under the hood, no chime. I had half of my employees helping me at different areas of the truck. The chime is only at or near the PCM, is there any way the test the PCM to know if there is a problem with it?
Old Aug 24, 2006 | 11:25 PM
powerstroker27's Avatar
powerstroker27
it wouldn't be a 5 sets of 5 beeps would it? Cause if so then its the same thing I have and Ive been told that it involves your airbags.
Old Aug 25, 2006 | 07:01 AM
Uzumati's Avatar
Uzumati
forgot about that one but if the Air bag light in the cluster is out it does have a backup chime warning
Normal Operation
The air bag indicator is designed to illuminate for 6 (+/-2) seconds when the ignition switch is turned to the RUN position. This initial 6 seconds of illumination is considered normal operation and is called prove out of the air bag indicator. The air bag indicator is then used to warn the driver that there is a fault in the air bag supplemental restraint system (SRS).
The restraints control module (RCM) monitors the air bag indicator for short to battery conditions. If the RCM detects a short to battery condition on the air bag indicator circuit, it will store a diagnostic trouble code (DTC) B1870 in memory.
If the RCM detects an air bag indicator failure in addition to another SRS failure, the RCM will send a signal to the generic electronic module (GEM) to produce five sets of five tone bursts
Old Aug 26, 2006 | 08:18 AM
IM1096's Avatar
IM1096
Thanks to all for the input, as always great information. It was the air bag light out in the dash. Pulled the 10 amp fuse to check it (it was okay) replaced it and all is working fine now. Thanks again.
