stuck in 3rd gear
Old Apr 7, 2002 | 03:28 PM
kandcrod's Avatar
kandcrod
Post stuck in 3rd gear
3 spd on the column , 63 f100 8 cyl., was doen shifting to second/ wouldnt go/ stuck in 3rd now. any ideas? help mr. wizard
Old Apr 7, 2002 | 06:36 PM
waxman's Avatar
waxman
stuck in 3rd gear
column shifts tend to get stuck. Try and shift it under the hood, you should be able to just move the linkage. Hopefully thats all your problem is.
Jimmy
Old Apr 7, 2002 | 07:29 PM
jowilker's Avatar
jowilker
stuck in 3rd gear
Kenny get a claw hammer and hook it on the shifter linkage closest to the fire wall and get it pulled up to netural. You should be good to go then.
TIP Always lift out of first with a slight pull to the wheel and when it is fully in netural let it fall fully and then lift in second. Never try to speed shift from first to second, unless you are willing to stop and get out to pull the linkage under the hood.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Apr 8, 2002 | 10:41 AM
44dwarf's Avatar
44dwarf
stuck in 3rd gear
Ken.
BLOCK BOTH SIDES OF THE WHEELS trust my flat toes!
What johns saying is true shift the truck like a H only sideways if you try to shift like a Y you'll hang it up for sure.
The problem liys in several spots.
1) Lower collum bearings wear out.
2) Lower collum wear face (thin platic sheet bettwen the shift forks)wear out.
3) collum shift tube wears.
4) Rubber bushings in linkage ends wear and dry out.
5) the trany's shift fork detent's (spring loaded ball) wear so thery don't "Snap" in to gear like when new.
All are "fixible" but it's not long before you'll need to do it again. So just learn to "H" it. Up forward up.
44Dwarf
Old Apr 8, 2002 | 06:59 PM
jowilker's Avatar
jowilker
stuck in 3rd gear
krzldy1949
1997 - 2003 F150
Mar 9, 2013 12:39 PM
Tee13ner
Aug 6, 2012 02:01 PM
trpltongue
17
Nov 9, 2011 07:42 AM
1959CustomCab
Jun 9, 2009 12:54 PM
