need more help,it never ends
Old Aug 24, 2006 | 11:59 AM
bobpat204's Avatar
bobpat204
well i am in need of help again.....1994 f-350 nonturbo dually,ive had the truck just over two weeks now and been fighting troubles the whole way ,today i towed my boat with it for the first time,hooked up the boat lights off i go get to the ramp and the "abs" light is on,park and shut off the truck and notice the brake lights are on with the truck off,on the way home the cruise control is dead along with the "abs" light.check the book both items are on the same fuse so i replaced the fuse it was blown.replaced the fuse stop lights are still on at all times the "abs"light is still on and cruise control is still dead,any ideas out there?
Old Aug 24, 2006 | 12:47 PM
Hamberger's Avatar
Hamberger
How is your speedo working?
Both the ABS, Speedo, and Cruise control rely on a signal from a sensor in your rear axle. (near the top left side of the differential)
The sending unit head is magnetic and over time picks up metal shavings from the differential and starts to give faulty readings.
I replaced a sending unit on my Dads 92 about 2 month ago, Cost: less than $30.
Seb...
Old Aug 24, 2006 | 04:09 PM
bobpat204's Avatar
bobpat204
thanks for the info, the speedo works fine no noted proplems at all,any place online to get a wiring diagram for the 94 f350? or will i have to buy one?i will pull the sending unit and give it a look.
Old Aug 24, 2006 | 06:53 PM
carnagez28's Avatar
carnagez28
Check your brake light switch. I havent checked on my truck yet, but their usually mounted above the pedal ...
7.3 Ex
Apr 27, 2020 04:36 AM
77_F150_4x4
May 13, 2014 01:36 PM
tigers2007
Nov 17, 2012 04:49 PM
trailmeisterjoe
Dec 30, 2005 09:35 AM
jrcf150
Aug 2, 2005 08:15 PM
