Fuel Tank Lines
Old Aug 24, 2006 | 07:20 AM
Monkey Man's Avatar
Monkey Man
Fuel Tank Lines
I replaced my first tank fuel tank on my 92 F150 super. Rear tank.
Question: of course after installing the tank and straps, function chk Great. Runs, fuel flows!!!
How important are those little metal clips that hold the the lines to the pump?!!
Of course after I filled it, I saw those two clips that I forgot. Dummy.
Is there vaccum pressure on those lines? Would it possibly cause a chk engine light to come on and off? Or any slight rough running?
Thanks all
MM.
Old Aug 24, 2006 | 07:58 AM
ness0012's Avatar
ness0012
if there was a vacume the lines would stay on onthere own. The lines are preasurized one pump in the tank one on the frame rail.
Old Aug 24, 2006 | 09:48 AM
Old_Paint's Avatar
Old_Paint
Dual tank, or single? If single tank, he's got one high pressure pump in the tank (just put one on my truck two weeks ago). I can't think of what straps he's talking about, because mine had the quick release fittings. Obviously, he's not talking about the mounting straps.
I'm not real sure if the low pressure pumps were used on dual tanks on the '92 models. Would have to ask some of the experts in here that study all the Ford Trivia.
Old Aug 24, 2006 | 11:18 AM
EPNCSU2006's Avatar
EPNCSU2006
Those metal clips are just safety devices - the spring clips inside the fitting should hold the fuel lines on the fuel tank fittings. All these trucks had high pressure in-tank pumps (both single and dual tanks) starting in '90.
Old Aug 25, 2006 | 06:39 AM
Scndsin's Avatar
Scndsin
My Ford documentation describes the clips as "redundant". In other words the lawyers made them put them there. So there must be a occasion when the connection will fail, but not very likely.
Old Aug 25, 2006 | 09:39 AM
ness0012's Avatar
ness0012
My rig is an '89 and I'm not lucky enough to have redundant clips. My clips keep the fuel lines from poping off. Well, those clips and many years of dirt and rust!! ;-)
craigm126
Nov 17, 2011 05:47 PM
turboboost
Nov 6, 2009 02:54 AM
FortyFords
Dec 8, 2006 07:20 AM
rhrmusic
May 1, 2006 08:27 PM
Quikirk
May 30, 2002 01:42 PM
