Trans Codes
Old Aug 23, 2006 | 10:26 PM
kiohio1985's Avatar
kiohio1985
Trans Codes
I have read a bunch of different threads on trans codes.
I have code 628 coming up. Converter Clutch Error.
Some of the threads have talked about the VSS, TPS and the MLPS being possible culprits, other than a bad TC.
My question is: Why wouldn't codes for these various sensors etc show up too?
My trans shifts very hard at times AKA "performance mode".
Other than that it doesn't have any other symptoms of trans trouble.
NO Shudder, no detectable (to me) slipping, Speedo works fine, no OD light flash.
The only other codes on the truck were(332) insufficient EGR flow detected and (172) HEGO shows System always lean.
Thanks KO
Old Aug 25, 2006 | 07:40 AM
kiohio1985's Avatar
kiohio1985
MPG 8.2 Mainly highway.
Starting to do repairs now.
KO
Old Aug 25, 2006 | 07:52 AM
shooter05's Avatar
shooter05
When my computer went bad It had fouled alot of other sensors and they were coming up with codes but in order to see the comp I had to fix everything that was bad before that. Seems to make sense once you think about it. If you have a string of A-B-C-D then C and D goes bad. You can't see that D is bad til C is fixed. Sometimes things will give false readings because they are getting bad data too.
Old Aug 25, 2006 | 08:50 AM
kiohio1985's Avatar
kiohio1985
Greaaaaat LOL.
I have a Love/Hate relationship with EFI.
Hopefully will get the mileage up. This thing should do better with 3.55 gears.
Heath huh? Cool,my truck came from Newark on 13.
Thanks, KO
Old Aug 25, 2006 | 09:05 AM
shooter05's Avatar
shooter05
Small world I guess. I have been stuck in the Newark/Heath area most of my life. I have 3.55 gears now and have been considering going to 4.10 since I run bigger tires and it seems kinda doggy. I have that on the back burner till I get my front end lifted about 3" to level it out.
Old Aug 25, 2006 | 10:13 AM
kiohio1985's Avatar
kiohio1985
Sounds like me and the Athens/Nelsonville/Logan area.
KO
