hydraulic roller reliability
Old Aug 23, 2006 | 02:36 AM
darrin1999's Avatar
darrin1999
im putting together a 545 and looking at a crane cams hydraulic roller retrofit cam and lifters. anyone know if theyll last 100,000+ miles like regular hydraulic flat tappets?
Old Aug 23, 2006 | 07:12 PM
RTM's Avatar
RTM
I would say they should out last the flat tappet lifets and cam. After all there is no friction with the roller cam and lifters.
I have no experience with crane for such a long time but I have never read anything that would make me not use them in a DD motor.
Old Aug 23, 2006 | 11:22 PM
airharley's Avatar
airharley
The only thing that will make them fail is the link that holds them together or the needle bearings losing lubrication. Other then that they will last almost forever. I talked to my machine shop about the durability of roller lifters. They are still using a set of lifters after 5 or 6 seasons of punishment at the track and driving it to and from there.
Old Aug 24, 2006 | 12:37 AM
monsterbaby's Avatar
monsterbaby
The factory has been using hyd roller cams for 15+ yrs if that gives you an idea.
Old Aug 24, 2006 | 11:45 AM
bronco521's Avatar
bronco521
don't use a windage tray,the more oil spashed on the rollers the better.
Old Aug 24, 2006 | 02:00 PM
monsterbaby
a windage tray won't hurt the rollers, remember the windage tray is under the crank your still going to get some spray on the top side of the crank even with a windage tray. And the windage tray has the advantage of getting the oil back into the pan faster allowing it to be recirculated through the engine instead of turned into a froth.
Old Aug 25, 2006 | 01:56 AM
bronco521's Avatar
bronco521
if he wants to get 100,000 miles ,the more oil hitting the needles in the rollers the better.
Old Aug 25, 2006 | 10:20 AM
rusty70f100's Avatar
rusty70f100
My '92 Explorer has a 4.0L V6 that came factory with a windage tray and a hydraulic roller cam. It currently has 221,625 miles, and runs like a top.
So yeah, go ahead and use the windage tray and hydraulic roller cam.
Now, if I was building a motor with a flat tappet cam, then I might think twice about the windage tray.
Old Sep 24, 2006 | 06:51 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Just watch your spring pressure's in a daily Driver..alot of guys will go crazy with the lift on the cam requiring higher pressure's..and then wonder why they have valvetrain failure's.... JMO.....
RJ
Old Sep 24, 2006 | 08:05 AM
darrin1999's Avatar
darrin1999
the springs i picked out are 99895-16
the recommended springs were a little higher spring rate and lower seat pressure... these are 403 lbs open and 144 seat, and are 1.54 inch od duals... theyre the best springs i could come up with from crane
the springs they recommended were 134 seat 424 open and 1.46 od... seemed too small to me for a rate of 448
