transmission problems
Old Aug 22, 2006 | 03:18 PM
cbjr61's Avatar
cbjr61
Unhappy transmission problems
1991 f150 302 4x4
problem is truck was driven a short distance in 4 high without the front hubs locked in one of kids pulled on shifter when it was parked and didn t notice it now truck will not go in any gear any thoughts on what happened and how to fix
another question is trany same for a 2wheel drive truck as it is for a 4wheel drive truck
Old Aug 22, 2006 | 09:46 PM
kiohio1985's Avatar
kiohio1985
Make sure the transfer case isn't in between gears.
I've had it happen to me.
It won't hurt it running in 4wd without the hubs locked in.
The parts all turn but don't do anything, except use a little more fuel.
The 4wd and 2wd transmissions are different.
KO
Old Aug 22, 2006 | 11:57 PM
kevsford88's Avatar
kevsford88
hey the transfer case is prolly just stuck in neutral just put it in 4 wheel the back to 2 then go through the gears should pop back in.
Old Aug 23, 2006 | 05:51 AM
cbjr61's Avatar
cbjr61
i tried pushing it back into gear but ill try it again but one other problem also noticed a puddle of oil under truck not trany oil it could be from transfer case its pretty black
Old Aug 24, 2006 | 09:18 PM
cbjr61's Avatar
cbjr61
added 7 liters of tranny fluid and now it works thanks for all your help
