F100 Identification
Old Aug 21, 2006 | 04:12 PM
TheSovereign53's Avatar
TheSovereign53
F100 Identification
Hi, I just got my first project, a 1953 F100. I know lots about them, and i know that an indentification plate is in the door jamb, however, at some point in my truck's life, this plate was removed. Is there anyplace on the chassis, or elsewhere, a VIN can be found?
Thanks
Old Aug 21, 2006 | 04:52 PM
mechmagcn's Avatar
mechmagcn
The VIN plate is mounted to the glove box door. Good luck finding the VIN on the frame, I have sandblasted the frame on my 53 and haven't found it.
Jeff
Old Aug 21, 2006 | 04:53 PM
Huntsman's Avatar
Huntsman
The ID plate is on the inside of glove box door and on the right front frame rail, between the firewall and the axle.
Welcome to FTE!
Old Aug 22, 2006 | 01:47 PM
59flatbedford's Avatar
59flatbedford
how come alot of the books say the plates on the door when its in the glove box. it took my a couple of weeks to find mine
Old Aug 22, 2006 | 02:31 PM
AXracer's Avatar
AXracer
they started putting them on the door post in 56.
Old Aug 22, 2006 | 02:32 PM
WillyB's Avatar
WillyB
Now you know what the books are worth - they are mostly written by people who have never worked on the truck.
No doubt the ID information was taken from a different book, updated to show what has already been published about the different codes, and sold as original work. Most "how to" and specialty books are little more than scams.
I was a technical writer, we called this sort of information boiler plate - the same text used in several different books.
Old Aug 22, 2006 | 02:33 PM
WillyB's Avatar
WillyB
Ax, the 57/60 years are on the inside of the glove box door.
Old Aug 22, 2006 | 03:33 PM
AXracer's Avatar
AXracer
OK, then ONLY in 56 did they put them on the door post!
Old Aug 22, 2006 | 06:14 PM
4tl8ford's Avatar
4tl8ford
On the 53 check the rear center of the front crossmember, you should be able to see it with the radiator in. Oh, you may need to remove several inches of crud first.
Old Aug 22, 2006 | 09:57 PM
TheSovereign53
Wink
Well, thanks guys! Except, now im stumped... I went through the pile of crap that came from the old owner, and this is great, no glove box door! Well, i guess its time to bust out the wire brushes and the flashlights!
hey, any good sites where i can try to find out some stuff on my truck when i find the elusive VIN?
[img]images/icons/icon12.gif[/img]
Old Aug 23, 2006 | 12:25 AM
mtflat's Avatar
mtflat
Sure - right here, but the early stamped vins are pretty basic and don't contain much info. Print what you find and someone will be happy to decipher it for you. You could also look in the tech articles/specs on the top of the page and find a link there.
Old Aug 23, 2006 | 12:51 AM
TheSovereign53
thanks for the help, when i get the chance im gonna post it here, FTE seems like an excellent site!!
Old Aug 23, 2006 | 07:01 AM
AXracer's Avatar
AXracer
Hate to say this, but the glove box door may have been removed so someone could use the vin plate to register a different truck. Do you have a title for the truck? If not, no real good reason to look for the original vin # except curiousity, you're probably going to have to register it as a homebuilt vehicle and have a new vin # assigned. Be sure to keep all receipts for all the major components you use on your truck, you'll need them come registration time.
Old Aug 23, 2006 | 07:14 AM
WillyB's Avatar
WillyB
I noticed your profile shows you as being from California - if you do not have a title I sure would address this problem now.
DMV will work with you now and you have several options - but if you show up there with a finished truck you can walk into several thousands of dollars worth of fines, or even have them take your truck as a stolen recovery.
It is well worth the trouble of getting a good title now, transfering it to your name and buying the plates, and then doing a non-op for the truck. Waiting will not make the fees any less, and you will know you can drive the truck when you get it done.
Old Aug 23, 2006 | 08:26 AM
1Digger's Avatar
1Digger
My vin (53) was stamped on the on the right (passenger) front rail, in front of the axle. I didn't find it until I blasted the frame. It wasn't stamped very deep and it is hard to see now that it is painted again.
