7.3 won't start when hot?
Old Aug 21, 2006 | 08:38 AM
jcarson1's Avatar
jcarson1
The trouble is this: It starts great when cold but when warmed up if you shut it off it will not even attempt to start. It cranks wonderfully but will not start. If you wait for around 30 minutes and try it will start right up again. It has new clean fuel filter, air filter. Anyone experienced this trouble?
Old Aug 21, 2006 | 10:14 AM
1997F-350's Avatar
1997F-350
ipr orings
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AN (F6TZ-9C977-AA?)
(International) 1825806C92 (1825806C91?)
Old Aug 21, 2006 | 11:24 AM
tjbeggs's Avatar
tjbeggs
yep ipr o-rings when the oil is cold it can build pressure better but once the oil is warm enough it thins out and slips right by those worn o-rings therefore not creating enough pressure (500 psi) to start the engine.
Old Aug 21, 2006 | 05:21 PM
1997F-350's Avatar
1997F-350
oh make sure you drain your hpop first. or your valley will be flooded with oil. you can do this job its pretty easy. i wouldnt pay anyone. ask away if you need help.
Old Aug 21, 2006 | 08:07 PM
sparkroost's Avatar
sparkroost
What is the resistive value of the IPR when cranking? Would be nice to know if mine ever did this. I could then just open my magic box of resistors and roadside fix it!
Old Aug 21, 2006 | 08:12 PM
1997F-350's Avatar
1997F-350
unfortunately its orings and not a resistor to fix this.
although you could bust out some tools and repair it that way.
edit: on 2nd thought maybe you could. dont now what kind of pressure would be present to light em off if you fooled the system but i am sure its possible as long as they are not too long gone.
6.whoa
Nov 16, 2016 03:47 PM
Tiffany Shock
1983 - 2012 Ranger & B-Series
May 15, 2015 01:36 PM
SketchyWolf
Jan 19, 2015 10:09 PM
Mihylo33
Aug 4, 2009 05:26 AM
86302
Sep 19, 2005 04:53 PM
