I have a 87 6.9 with a C6. I shakes in between 2nd & 3rd. If I let off the pedal it shifts & quits. Could it be the speed sensor? Or is it pry the vacuum control. I will have to take it in if that's what it is. I don't have a way to pull vacuum on it to check it. I appericate any help.
There is a valve on the throttle linkage at the IP that controls the vacuum sent to the tranny that could be out of adjustment.
Also your vacuum pump could be getting weak, does you heater switch from floor to defrost OK? That is one sign it is going out.
I am not much help on automatics, I only know what I have read in this forum.
There are others that have much more experience than I with automatics.
Have you tried adjusting the bands? If not adjusting the bands should solve your problem. Most likely it is the 2ND gear band that is making it do that.
The 2nd Band is on the outside and on the drivers side I'd have to look to see where the reverse band is cuz its been so long since i have worked on a c-6
