Sponsored by: Real Truck
tire preassure
Old Aug 20, 2006 | 09:08 PM
Jocaren's Avatar
Jocaren
tire preassure
what tire preassure do you run for best driving, mine now are at 50-55 psi, will i get better gas mileage if i set them at 65 psi? they are rated for 80
06 4x4 f250
Old Aug 20, 2006 | 09:56 PM
6.0 Rules's Avatar
6.0 Rules
I tow all the time (full timer). I have a 6.0L '03 F250 Lariat towing a 12k# 5th wheeler, and inflate rear tires at 70psi, and the front tires at 60psi (Ford recommended). The tires are Goodrich A/T. Hope this helps.
Old Aug 21, 2006 | 05:58 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Moved to SD ...here
Old Aug 21, 2006 | 06:44 AM
stewcon's Avatar
stewcon
75# all around as I haul building supplies and a trailer about 70% of the time. I also have tool boxes mounted on the bed rails.
Old Aug 21, 2006 | 07:55 AM
jeffwoehrle's Avatar
jeffwoehrle
125 Pounds !!
Old Aug 21, 2006 | 09:26 AM
TNT in Round Rock's Avatar
TNT in Round Rock
my BFG AT's state 50psi max on the tires .. i run 50 front, 45 rear
Old Aug 21, 2006 | 09:42 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
I have the 20" Goodyears, I run them at 60 lbs, as the factory recommends.
Old Aug 21, 2006 | 12:02 PM
77460f150's Avatar
77460f150
I run 50 psi front and rear BFG A/T's 315/75-16, towing my 77 F-150 usually. -Ed
Jim Hunt
16
Oct 17, 2010 12:38 PM
Bricks88
3.8 & 4.2L V6
Jan 15, 2009 02:26 PM
bigtorque
Feb 1, 2007 10:21 PM
