Sponsored by: Real Truck
Shock life exectancy
Old Sep 4, 2003 | 05:55 PM
huckster's Avatar
huckster
Wondering what the life exectancy for the factory shocks on a '99 SD CC 4x4 is. What is a resonable replacement? Just looking for a general duty replacement. Thanks huckster
Old Sep 4, 2003 | 06:21 PM
99f350sd's Avatar
99f350sd
I have 80k on mine and they are still good. Meaning no leaks and still gas charged.. If I were going to put new I would go with blistens....
Old Sep 4, 2003 | 08:31 PM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
Life expectancy is about what it takes to go on a test drive, IMHO.
I replaced mine at about 30K. They seemed OK at the time (no leaks, passed the "bounce the truck" test, etc). Once I got them off, however, I noticed that instead of extending out the way a normal shock should, they just froze in place. I had to push them in and release a few times to get them to fully articulate. Even then, it wasn't a smooth motion. Mind you, these shocks hadn't had any abuse in their lifetime.
After replacing them, I wish I had done it sooner. I went with Edelbrock Performer IAS shocks. I recommend them to anyone who asks. Others have had good results with Bilsteins, but they are a somewhat "firm" shock. You can't lose with either one, though. Don't try to save a few bucks and buy something cheeper. You'll get your money's worth with either of these.
BTW -- in case you're curious, replacing shocks on these trucks is a simple driveway job.
Old Sep 4, 2003 | 10:19 PM
daimon1054's Avatar
daimon1054
30 is about max. Remember the reason so many people think a new shock is SOOO much better than the old is because performance goes away so slow you neve notice it. Then when you change it is like MAN I should have had these from new.
The oil inside breaks down from shear and heat then looses viscosity. So just because you do not see a leak does not mean they are good.
Old Sep 16, 2003 | 09:49 PM
V10 Eddie's Avatar
V10 Eddie
I've have 58K on my stock shocks and the steering stabilizer appears to be leaking as well. Does Blistein or Edelbrock make one to go with their shocks? I like stuff to match and I don't want like to throw $$$ away on products that I don't need, but like to get the best for the dollar.
Sounds like everyone likes these two brands for replacements and the Rancho's arn't the best way to go?
Old Sep 17, 2003 | 07:38 AM
powerstroker250's Avatar
powerstroker250
ALL mine were leaking at 25k.
Old Sep 17, 2003 | 08:53 AM
Big Orn's Avatar
Big Orn
Got 78k+ here and needed new ones at 60K. Just hadn't got around to it.
Anybody got a little round tuit I can borrow?
Old Sep 17, 2003 | 12:46 PM
bddo's Avatar
bddo
I've got the Rancho 9000's on my truck, and I love them. I've read alot on here about the Bilsteins and Edlebrocks, and I'm sure they are good too, but I don't understand why Rancho's get such a bad rap.
If I had a lift, I would probably go with Bilsteins, but with no lift, the Rancho's work fine. The adjustability of the 9000's really makes it nice, especially with the in cab controller. I can go from soft to firm in about 20 seconds, which helps when I'm towing my 29 foot travel trailer.
Besides, they look great and match the Rancho steering stabilizer..
Just my opinion...
Old Sep 17, 2003 | 01:32 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Ditto on Rancho's...
I put on RS9000x's at around 7K miles. The original shocks still had gas charge and moved freely (too freely). The day I test drove it with 23 miles on it, I thought "gotta change those shocks".
Put a rear Hellwig sway bar on it too, which made EVERYTHING all right...
My '74 F250 has Ranchos on it for the last 12 years. Still going ...
ak
Old Aug 21, 2006 | 11:21 AM
mrc59's Avatar
mrc59
I suppose lifespan is a relative term, as long as you can't see any visible signs of failure. However, at 35K I just replaced my '04 factory shocks with a set of Edlebrocks, and I can't believe the difference. It's like test driving a new truck.
Old Aug 21, 2006 | 12:45 PM
krewat's Avatar
krewat
This thread is almost 3 years old.
