Tire Size
Old May 11, 2002 | 05:57 PM
brianwbo's Avatar
brianwbo
Tire Size
Ok Just wondering what is the widest tire and rim combo, I can put on my 65 F-100. Ok then say I wanted to go big, anyone with any websites on tubbing a 65 f-100. I have tubbed several cars working at a racing fab shop, but have never tackled a F-100. The body work part to the bed is no problem, its just the frame, I need help with. Thanks
Old May 12, 2002 | 09:07 AM
truckfarmer's Avatar
truckfarmer
Post Tire Size
If you move the leaf spring mounts to the inside of the frame it will open up a lot of space without even cutting the frame. At least 4" per side. For a sleeper look, get wheels with lots of offset to use all that new room and not even narrow the rearend. From the outside will look stock. They won't know any difference till yoo are in front of them.
Old May 13, 2002 | 06:17 PM
packrat_1954's Avatar
packrat_1954
Tire Size
Old May 14, 2002 | 09:19 PM
brianwbo's Avatar
brianwbo
Tire Size
Ok that makes sense, and seems pretty easy. I have one question, moving the leaf spring mount to the inside is possible, but there are frame supports along the inside. Do I move these around a little. there are two parallel supports with the rear and the front mounts for the leaf springs. I am pretty handy with a torch and a mig welder. Just remove the supports, to a new place and reweld the leaf spring mounts on the inside of the frame. Ok has anyone seen this or done it. Is there and bad things associated with this. Is it worth the work, or am I going somewhere I should no venture, and leave it alone. The main rason I am doing this is a want wider tire, without cutting the frame. Please let me know.
paw_paw
Jun 12, 2011 08:11 PM
Cheshire Cat
1966 - 1977 Early Broncos
Aug 31, 2006 01:19 PM
Vee
Mar 13, 2006 09:30 PM
65_sleeper
Aug 1, 2005 06:30 PM
1956f100
Jun 1, 2004 04:17 PM
