electical issues with marker light
Old Aug 19, 2006 | 02:05 AM
dirtinit's Avatar
dirtinit
Question electical issues with marker light
started the other day Iwent to turn off lights but the marker light wouldn't turn off pulled fuse that didn't help still on also pulled head light switch out still no go. only way to turn out was to pull the battery's ground side and put back on then the lights stayed out . now if i lock the doors with the remote(stock keyless entry) or turn on and off head lights the marker lights stay on . does any body know where the relay is ????????
Old Aug 19, 2006 | 06:13 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 19, 2006 | 07:10 AM
Uzumati's Avatar
Uzumati
Only relay I could find is the Flasher Relay rest looks like it is controlled by the GEM and light switch assembly. I have a pdf of the wiring diagram if you need it
Old Aug 19, 2006 | 09:59 AM
dirtinit's Avatar
dirtinit
wiring diagram
how about the park lamp flash relay thats powered from fuse-26 20 amp in the engine comp. look like it may be part of the remote keyless entry??
Old Aug 19, 2006 | 01:30 PM
kennedyford's Avatar
kennedyford
Just an idea that maybe there is a backfeed in the wiring?
Old Aug 24, 2006 | 01:07 PM
dirtinit's Avatar
dirtinit
Red face issue found
found that it was a feed back from the trailer wire harnness from the plug on the bumper didn't think to look there sence I never use it.
thanks for all the help
