Aerostar Ford Aerostar
battery drain
Old Aug 20, 2006 | 01:23 PM
cookkd's Avatar
cookkd
Originally Posted by Schroder
The one that is drawing the current is yellow and it is hooked to a blue which I beleive is the ignition and then there are also two black wires hooked to it.
how can I delete this entry?????????
Old Oct 19, 2006 | 09:23 PM
teg3's Avatar
teg3
on the above post about the alternator diodes being hot when the engine is cool.And I checked it was hotter then hell..but would you say if I disonnect the battery it should be cold ?if I recoonect the battery it will heat up ? So then the alternator is bad ?
right now the alternator puts out 12.8 amp and should be 14 or more..Either a short
is causing the drain or the diodes on the alternator.Would you agree ?
Old Oct 19, 2006 | 09:53 PM
ken1mod's Avatar
ken1mod
You have bad diodes in the alternator. these prevent current from backing up from the battery when engine is off. there are six of them and at least one is shorted causing the battery drain and lowered power output.
Replace alternator.
Ken
Old Oct 20, 2006 | 03:20 PM
teg3's Avatar
teg3
Would a burned out fuseable link also cause simular problems ?
Old Oct 20, 2006 | 04:31 PM
ken1mod's Avatar
ken1mod
Nope. Nope.
Old Oct 20, 2006 | 08:15 PM
96_4wdr's Avatar
96_4wdr
burned out fusible link indicates there is a high current, greater than current rating of the link, short somewhere in circuit beyond fuse link....either to ground or another circuit...or a device drawing too much current such as a dragging fan motor
Old Oct 21, 2006 | 04:13 AM
teg3's Avatar
teg3
sometimes the battery indicator light comes on. the battery is new.the alt puts out 12.8 amp.maybe a short or just out right bad alt.
Old Oct 22, 2006 | 08:51 AM
teg3's Avatar
teg3
New thing with a fully charged battery now dead.But the alt is not hot or warm from what I can tell drained the battery.Can the alt cause all this or the volt reg also ?
it never did it before .Any opinions help full
Old Oct 22, 2006 | 09:47 AM
Bear River's Avatar
Bear River
Former ******
Are the battery terminals fully cleaned? It is also possible that the battery could be internally shorted. Most likely it is the diodes that have failed.
Old Oct 22, 2006 | 01:38 PM
96_4wdr's Avatar
96_4wdr
with fully charged battery pull all other smaller leads off large lug on starter relay that positive red lead from batt. goes to...
tap each one to red battery lead looking for a spark....spark=culprit circuit
none sparking
use DVM current meter and measure current draw of each circuit lead to pos + battery lead
there will be 1 to PCM clock and radio that normally draws less than 10ma with key off.....all others should be zero 0 nada nothing
Old Oct 22, 2006 | 05:04 PM
Bear River's Avatar
Bear River
Former ******
My suggestion, go to your local auto parts store and have them test your chargeing/starting system. Chances are that this will help locate the source and eliminate several possible culprits.
Old Oct 22, 2006 | 06:18 PM
teg3's Avatar
teg3
I did do that and was told it was putting out 12.8 amps they suggested either bad alt.or a short somewhere.After I replaced the battery.put it in it showed a negative draw on the gage.Let it rest and by the next day the battery was completely drained
and this has only bin the last few days.Prior to this no problems indicated.
Old Oct 22, 2006 | 06:43 PM
  #28
copper_90680's Avatar
copper_90680
Teg3:
One sure way to see if the alternator diodes are bad is to remove the big wire from the back of the alternator, but tape it up well and make sure it does not touch any metal parts. Also, make sure you disconnect the battery before trying to remove that wire, then reconnect the battery after you are done.
If removing that eliminates the drain on your battery, you have a bad alternator. If not, you have to start pulling fuses one by one to see which circuit is causing your short.
Old Oct 22, 2006 | 11:01 PM
  #29
Bear River's Avatar
Bear River
Former ******
Bad alternator diodes or not, 12.8 amps is unacceptably low. Should be at least 50. At that rate, the power consumption of the vehicle exceeds the alternators output, and the battery will never charge. I would follow the auto parts stores recommendation on this one, the test automatically eliminated other causes, because it checks for alternator load, and stray current. If it had found stray current, their machine would have caught it. You need a new alternator my friend. The only other thing I could suggest is to make sure the battery cables themselves are not corroding inside.
Old Oct 31, 2006 | 01:40 AM
  #30
haslipe's Avatar
haslipe
Mine was the the light under the hood. I guess it had a mercury switch that was out of place. I just unplugged the bulb and my battery problems went away.
