Sponsored by: Real Truck
Weird Tranny Problem
Old Aug 17, 2006 | 11:08 PM
TchTchr's Avatar
TchTchr
Hello all,
I'm new to Ford trucks, but have worked on my vehicles for years. OK, hears the deal: '01 F-250 ran fine, made grinding noise at idle and stalled. Grinding went away as well as the stall. Now after sitting overnight, the truck barely wants to move when put in gear (automatic). After going about a block, it takes off and shifts fine and will continue to all day even after parked for several hours. The next morning it doesn't want to go again. It does this everyday. Any clues?
Thanks
Old Aug 18, 2006 | 08:10 PM
FoMoCo05's Avatar
FoMoCo05
How is the fluid ?? Have you serviced lately ?? I would start there and flush the whole system.
Good Luck - Rick
Old Aug 20, 2006 | 07:05 AM
TchTchr's Avatar
TchTchr
The tranny is only a couple of months old. I thought I would see if there was an "easy" fix before I pulled the unit and sent it back.
Old Aug 20, 2006 | 09:29 AM
jake00's Avatar
jake00
I'd look aat the fluid
Old Aug 20, 2006 | 10:22 AM
FortyFords's Avatar
FortyFords
I would drop the pan and see how much metal is on the magnet.
was the system flushed when putting this unit in? If not metal particles left in the coler /lines will kill the new unit quickly
Rich
Old Aug 21, 2006 | 11:34 AM
Flipper_1938's Avatar
Flipper_1938
Mine did that at the 65,000 mile mark.
Wife called said the truck wouldn't go.
I show up, put it in gear and drive just fine.
Then the problem happened again...along with the noise.
Two days later, catastrophic failure.....broken **** rattling around in the transmission. Very little in the transmission was salvageable.
