Help with tire size
Old Aug 17, 2006 | 04:31 PM
plumwagon's Avatar
plumwagon
Talking Help with tire size
Hello, First time poster. Last month I bought a 2003 X (33,000 miles) with the 6.0 Diesel, leather, dvd etc..Two days after purchase I drove the family from CA to Montana for vaction. I know the 6.0 have problems but the X performed exceptional getting 18-20 mpg at 85mph. The E350 V-10 van we turned in would only get 8-9mpg during the same trip. Anyway I would like to put 305 / 75 tires on and was wondering what is the minimal lift I will need to fit these tires. The X just doesnt look right so low to the ground (2 wheel drive). Any suggestions would be appreciated. Thanks
Old Aug 17, 2006 | 07:48 PM
fishintheobx's Avatar
fishintheobx
I have a 2005 4x4 X 6.0 and would like to go with a 20" wheel, and am just as interested in knowing the maximum tire size I could do without a lift.
Old Aug 18, 2006 | 05:32 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 18, 2006 | 08:49 AM
dsldandually's Avatar
dsldandually
try the 295/75/16's they are alittle narrower and just as tall. the narrower tire will help you maintain some of your mileage
Old Aug 18, 2006 | 10:15 AM
tarpontwo's Avatar
tarpontwo
i have a 4x4 6.0 X with 305/75/16's and it doesnt even rub, they are bfg m/t's
and thats with no lift at all, just stock
Old Aug 21, 2006 | 01:04 PM
plumwagon's Avatar
plumwagon
Thanks for the info..so even though the X is a 2wd I can fit a 295/16 tire without a lift, is this correct?
Old Aug 21, 2006 | 01:22 PM
fomoco_1's Avatar
fomoco_1
NO ! You will need about 2 inches of lift on a 2wd.
Old Aug 21, 2006 | 01:36 PM
plumwagon's Avatar
plumwagon
Thanks for the reply..Can you reccomend a good 2" lift and from where? I saw an X this weekend and it had a set of GRABBER AT2 295/75 R16 and a very small lift if any. I really liked the way it looked and I want the same tires on mine, I just need to know what its going to take to fit these tires...
Old Aug 22, 2006 | 02:43 PM
fomoco_1's Avatar
fomoco_1
Well, you can go in a few different directions on lift. You can install Ford V code springs and different shocks as one route. Donahoe makes a good 2" lift that you won't have to change out the springs,but its a little on the pricey side. Check with a 4x4 shop,they may have some F-250 springs and u-bolts lying around they would sell you on the cheap. Good luck !
Old Aug 22, 2006 | 02:52 PM
fomoco_1's Avatar
fomoco_1
About the biggest you can go with without a lift using a 20" x 10" wheel would be 325/55/20. 325/60/20's will work but may have a scrub issue. The way to accomidate this is to remove the screws holding the wheel well liner and push or jack the liner back toards the drivers compartment and reinstall the screws. You may have to trim a little of the plastic from the underride bar trim below the bumper also. Take your time and mark where you want to make the cuts. Use a sharp,not necessarily good, knife and heat it with a propane torch to help out. I know this works. i did it to my brothers '02 4x4 X. Good luck and post some pics when ya get-er-done.
Old Aug 22, 2006 | 02:53 PM
fomoco_1's Avatar
fomoco_1
About the biggest you can go with without a lift using a 20" x 10" wheel would be 325/55/20. 325/60/20's will work but may have a scrub issue. The way to accomidate this is to remove the screws holding the wheel well liner and push or jack the liner back towards the drivers compartment and reinstall the screws. You may have to trim a little of the plastic from the underride bar trim below the bumper also. Take your time and mark where you want to make the cuts. Use a sharp,not necessarily good, knife and heat it with a propane torch to help out. I know this works. i did it to my brothers '02 4x4 X. Good luck and post some pics when ya get-er-done.
Old Aug 23, 2006 | 12:57 PM
plumwagon's Avatar
plumwagon
I want the 295/75 AT Grabbers put on the 16" factory rims. What is the best way to accomplish this without bying new 20" rims. Anyone with suggestions or who has put 295/75 on their 2wd X ?
Caleb1
May 8, 2009 06:57 AM
Montana2mass
Sep 26, 2008 09:18 AM
Montana2mass
Sep 25, 2008 07:31 PM
rogersdan
26
Jul 24, 2006 11:18 PM
bigskydiesel
Computer Chips & Tuners
May 19, 2004 03:29 PM
