Help!
Does any one know of a source for a 16" tubeless wheel, 6 bolt pattern on 7.25 circle to fit a 65 F350 with duals?
Tried the forum search, came up empty.
Thanks for any help.
I also need one-piece tubeless wheels for my F350. Contacted Stockton and will probably buy from there, although the ones I wanted (painted Powerwagon II 16.5s) are $220 each. Is there any other source to check out? Does anyone here have experience with Stockton, or sourcing these wheels?
I got a 1965 F-350 Dually
when i bought it, it came with 4 rims.
Right now i'm running two 16" 6 lug Budd Split rims (the stock ones) in the front
I'm running two 17.5" solid one-piece rims in the rear. I'm not sure where they came from, liek i said, that's how i got the truck. i do know that 1957-1960 dodge power wagons ran the same 16" split rims...i'm right in the same boat as you guys, i need to find some rims for my truck, i don't even care for how much money, but i want one-piece 16" dually style rims with tubeless tires
Stockton wheel is good. Another source could be American Wheel Specialist in Pasco, Washington. Just to throw some options out there. International pickups also used the Budd 6-lug wheels.
I have a set of 7 of the 17.5" tubeless dual wheels with at least 4 pretty new tires, and all 7 hold air, 6 radials and one bias ply. Just drove cross country, no tire problems.
They are for sale or trade.
I need an axle with 3.54 or faster gears, fits dual wheels of any common bolt pattern, and is 8' or less wide with wheels installed. Will also trade for Detroit Diesel 53 series stuff.
