7.3 wake up?
Old Aug 16, 2006 | 12:49 PM
79 FORD's Avatar
79 FORD
7.3 wake up?
I have an old 7.3 IDI Its a 1990 and isn't anything too special just an old plow truck. I was wondering what cheap mods or adjustments I could do to wake this high miler up?
Old Aug 16, 2006 | 09:22 PM
powerstroke6ltr's Avatar
powerstroke6ltr
Open up the exhaust if you are on stock. This won't do much, but it will help reduce backpressure. Is there a turbo?? If so you can turn up the fuel a little, but it is advised not the tinker with the fuel screw w/o a pyro. A better flowing airfilter may help...
Old Aug 16, 2006 | 10:50 PM
79 FORD's Avatar
79 FORD
Can I turn up the pump without a turbo? And with that have a bigger intake better flowing air filter and a bigger exhaust?
Old Aug 17, 2006 | 09:48 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Diesel secret #1, lots of cool clean air supplied to the engine.
Diesel secret #2, a big easy way to get rid of the exhaust gasses.
Are you seeing any black smoke while you drive?
No black smoke, turn the fuel up a little bit till you see just a light trail while pulling a hill.
If you see black smoke, you need more air in before it can burn any more fuel.
Old Aug 18, 2006 | 01:53 PM
79 FORD's Avatar
79 FORD
I'm not getting enough fuel for black smoke....yet.So I want to turn the pump up enough to get a haze while pulling or on hills? Easy enough but after turning the pump up should I get a less restrictive exhaust?(mines pretty much stock now)
Old Aug 18, 2006 | 08:43 PM
Dave Sponaugle
Actually you should do the exhaust first.
Any intake or exhaust mods will change the amount of air going through the engine at a given RPM.
If you do the pump first, then work on the intake and exhaust, you will just wind up doing the pump again once it is getting more air.
Old Aug 20, 2006 | 12:44 PM
wh336fire's Avatar
wh336fire
I have been playing around with mine the last couple of months and she is really running sweet .
I installed a set of stan's headers so I could run true dual 3" exaust to my dual 3" stacks.
I also have been working on my ram-air intake . Haven't perfected it yet , but it's coming along .
The latest change is now I'm running her on Waste Cooking Oil . Runs great and smells like a fish cooker . My fuel is averaging about 30 cents a gallon . I've run it about a 1000 miles so far . Still playing with it .
Old Aug 20, 2006 | 02:33 PM
79 FORD's Avatar
79 FORD
Wouldn't headers rob some low end torque though?
Old Aug 20, 2006 | 05:26 PM
Dave7.3's Avatar
Dave7.3
I also have been working on my ram-air intake . Haven't perfected it yet , but it's coming along.
How much power increase do you see from those headers? From what I hear from Stan's Headers, they say a 55 hp increase (which I kinda doubt). Basically, is the $550 worth it?
Old Aug 21, 2006 | 10:25 AM
wh336fire's Avatar
wh336fire
I feel like I have gained some low end . Revs up pretty quick also . Awsome sound with the open headers , it was a loud ride to the exhaust shop .
I don't know how much hp gain , but I am very happy with the power . My wife and I have almost identical trucks , hers with the 5speed and mine with the 4speed . Hers use to feel stronger than mine , but now I believe I can walk off and leave her on the short run .Now when I drive hers it feel like I'm dragging a trailer . Hers is all stock , I don't think I want hers to run too fast . She's a little heavy on the go pedal .
Fullcrew7.3
62
Jan 4, 2010 08:13 AM
burncoat
Dec 8, 2009 10:38 PM
3Mike6
N. California Chapter
16
Aug 3, 2008 12:02 AM
Ruthless recovery
General Diesel Discussion
Feb 5, 2007 01:35 PM
PSTRK73
New Member Introductions
Feb 16, 2006 07:09 AM
