'04 Excursion Tire/Wheel Upgrade
Old Aug 16, 2006 | 09:37 AM
gmcbride's Avatar
gmcbride
Talking '04 Excursion Tire/Wheel Upgrade
I know this should probably be in the tire/wheel forum, but here goes... Does anyone know if a set of 4 factory 2006 F250/F350 20" wheels (rim size 20X8)with an 8 lug bold pattern will fit? They are being offered at $1,700 along with 275/65/20 Goodyear Wrangler AT/S but I am concerned about backspacing, etc. Thanks.
Old Aug 16, 2006 | 09:48 AM
Brians97F250Crew's Avatar
Brians97F250Crew
Um .... I think there was something on this in the 6.0L forum or somewhere. I belived the problem was the back spacing is different on the two years
The 2006 rims will be sunk into your fenders more. Probably look funny. You could get spacers but that's more money.
Old Aug 16, 2006 | 10:09 AM
X-Hibition's Avatar
X-Hibition
It won't fit because the wheel is off of the new coil spring suspension and we have (even in 2005) the older leaf spring suspension. Completely different offsets on the wheels.
Old Aug 16, 2006 | 12:25 PM
bucky440's Avatar
bucky440
Didn't Ford chamge the bolt circle also?
Old Aug 16, 2006 | 12:26 PM
Brians97F250Crew
I believe that change was only between the OBS trucks and the new ones. 1997 & earlier are one bolt pattern and the 99-up are the other.
Scott Clearman
2015 - 2020 F150
Mar 1, 2017 09:54 PM
Jbhawx
2009 - 2014 F150
Jan 16, 2017 12:28 AM
CodaMan
Oct 28, 2016 02:11 PM
Freedom1955
2015 - 2020 F150
13
Aug 29, 2016 05:41 PM
Kdr358
Mar 22, 2016 04:31 PM
