Sponsored by: Real Truck
a/c problems
Old Aug 15, 2006 | 11:30 PM
7.3LF3506X37's Avatar
7.3LF3506X37
a/c problems
I have a 99' F-350 7.3L powerstroke and i'm having a/c problems, the a/c will only work on high speed but not the other 3 speeds also when it is really hot outside the a/c will not work at all, i have replaced the switch and the blower motor. my wifes dad said it might be a vacuum hose but i'm at a loss. can someone please help?
Thanks
SGT
Old Aug 16, 2006 | 06:18 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 16, 2006 | 08:28 AM
jtmerritt's Avatar
jtmerritt
Smile
This sounds like it could be your problem. It is from the PSD service CD.
John
The heater blower motor switch resistor has the following features:
  • The assembly is located on the evaporator core housing in the engine compartment.
  • Three resistance elements are mounted on the resistor board to provide four A/C blower motor speeds.
  • Depending on the heater blower motor switch position, series resistance is added or bypassed in the A/C blower motor circuit to decrease or increase A/C blower motor speed.
  • An overheating protective device (thermal limiter) will open the resistor coil circuit when the temperature reaches 121°C (250°F) , interrupting the blower motor operation in all speeds except HI.
  • The thermal limiter cannot be reset and is not repairable.
Old Aug 16, 2006 | 10:31 AM
7.3LF3506X37
Ok, I will try to replace the blower motor resistor.
Thank you
Sgt
SilentlySoaring
Oct 6, 2020 09:47 PM
Melendez7.3
Sep 28, 2014 09:35 PM
mccloudfam1
Jun 27, 2013 07:43 PM
copracr
WTB - Ford Trucks & other vehicles
Aug 1, 2012 04:31 PM
